Fenix 8 Developer Mode
Hi! I just recently started developing a watch face and the device I have at home is Fenix 8 43mm. When I read up on how to side load my prg file to the watch, this process involves setting the watch in developer mode. I can however not find this setting on my watch.
Anyone with any clues?
I should perhaps also add that my computer is a MacBook (M2) and connecting the watch does not "mount" it in such a way that I can transfer files to it.
Garmin Express successfully finds and connects with the watch when its plugged in.
Thanks in advance!
Top Replies
All Replies
  • When I read up on how to side load my prg file to the watch, this process involves setting the watch in developer mode. I can however not find this setting on my watch.
    That's because "developer mode" doesn't exist on Garmin watches, regardless of what google ai, chatgpt, or any other llm may have told you.
    Modern Garmin watches (and some of the newest Edge devices) use MTP for file transfer, as opposed to USB Mass Storage (as in very old Garmin watches and slightly old Edges).
    Windows supports MTP natively, but macOS does not.
    To transfer files to your Garmin device using macOS, you need 3rd party software such as https://openmtp.ganeshrvel.com/. Note that Garmin Express should be completely closed before using openmtp (including closing the Garmin icon in the menu bar). If you use openmtp often, you may wish to disable the option in Express which keeps Express open in the background.
    It's too bad there's no official Garmin developer documentation which mentions this (afaik), despite the fact that MTP has been in use starting with the earliest Garmin watches which support music (released in 2018). Only conclusion I can draw is Garmin (as an org) doesn't care.
    That's what the forums are for, right? For the "community" to provide free support where Garmin won't.
    MTP tech notes and background:
    Advantages of MTP: operations are atomic (no need to eject device), no direct access to underlying filesystem (so it can't be corrupted, and it makes it easier for Garmin to prevent users from accessing sensitive data of arbitrary size, like Spotify music, without having to reserve a fixed amount of space for said data)
    Disadvantages of MTP: slow, no direct access to files (e.g. to edit a file, you typically have to copy it from the device and back)
    I'm fairly sure Garmin switched to MTP because they added support for on-board music / Spotify. Before that, they still had certain data which was inaccessible to the user (presumably on a different partition than the user-accessible partition via USB Mass Storage), but I think that approach would have required reserving a certain amount of space for a 2nd partition, which wouldn't be suitable for user data of fairly large and arbitrary size like music.
    With MTP, both visible and "hidden" data can be on the same partition (in different folders), but Garmin can completely prevent access to the "hidden" data simply by not exposing it via MTP.
  • Amazing post buddy. You're right - it was actually AI fooling me in the direction of some developer mode - guess it sounded plausible enough to pursue... Anyway - very kind of you to spend your time like this, hopefully it helps more people in the future. Have a nice rest of the day!
  • Hopefully people will stop posting AI code here! Or at least they should declare it in the beginning of the post!
  • Developer mode on the Fenix 8 is still there but hidden deeper now compared to older models.
    To enable it: go to Settings > System > About, then tap the model name (Fenix 8) repeatedly until it asks for confirmation. Enter the code 320000 (or sometimes 000320 depending on firmware) and it unlocks the dev menu with CIQ options, simulator toggle, etc.
    After that, the Connect IQ menu appears under Settings > System > Developer. Works on the latest beta firmware as of early 2026. If it doesn't prompt, try holding the light button while tapping About. Let me know your exact firmware version if it refuses to show up.
  • Let me know your exact firmware version if it refuses to show up.
    Let us know you, or ChatGPT?
    To the human ultimately behind this post (at whatever level of removal):
    If your goal is discourage real humans from posting real answers to real problems, keep it up. Thanks to people like you who previously spammed the internet with SEO-tuned slop, and now LLM-generated slop, eventually there will be nothing but slop on the internet. When people actually need help, they probably won't be able to turn to a public forum / subreddit / Q and A site (rip stackoverflow) whatever equivalent which is indexed and searchable by google. I've already seen some forums go private because of LLM scraping.
    On the bright side, maybe the entire tech industry will collapse and we'll all spend our free time doing stuff that's actually productive and healthy.
    I don't even know what you hope to gain by posting here - this is a niche forum with like 5 regular posters. I guess it could be a sophisticated form of trolling where your goal is to elicit exactly this kind of response. If so, congrats.
  • Its nuts what the internet has become.
    Anyway - OpenTMP worked like a charm, was able to load the watch face by transferring the prg to the GARMIN/APPS folder. Thanks a lot for your guidance!
