v2.2.1
General Changes
Update the compiler to include warnings when a module and class share the same name.
Prevent zero/negative width characters in custom fonts.
Fixed directory name build exclusion bug. Now excluding “source_fenix3” won’t also exclude “source_fenix3hr”.
Fix compile time error with using clauses when trying to use a previously defined ‘using’ label in another ‘using’ label.
Fix bugs in the “Not all code paths return a value” and “Variable used before being initialized” error detection logic.
Update the Windows monkeydo script to prevent shortening of PRG file names.
Enable limited Selectable functionality in data-fields; the Highlighted state is not possible in this mode due to input restrictions. Remove support for Buttons and View.setKeyToSelectableInteraction() when in data-fields.
Various fixes related to stability and security.
Updated Programmer’s Guide, UX Guide and API documentation with fixes and new additions.
Simulator Changes
Fix issues which may cause a crash when trying to download FIT files.
Fix a crash that occurred when clicking a progress bar.
Add an ANT+ sensor dialog that shows ANT+ sensor and allows pairing and unpairing.
Add menu item to clean up persisted content storage within the simulator.
Fix “pen” set-up issues to draw primitive shapes correctly.
Update monkeydo.bat to support /t and -t, and correct the Programmer’s Guide to specify use of -t for Run No Evil commands.
Fix vivoactive HR swipe direction definitions.
Fix NumberPicker / isSleepMode missing on Connect IQ 1.x simulated devices (fenix 3, Forerunner 920xt, etc).
Add a 240x240 Round Device.
Deprecate Round Watch, Square Watch, Semi-Round Watch and Tall Watch generic devices. If one of these generic devices is detected in a manifest file at compiler time a warning is printed indicating the device will be removed in the future.
