Issue installing application on Garmin Forerunner 955
Hello
I would like to ask why I am unable to install my application on my Garmin Forerunner 955.
With my previous device, the Forerunner 235, I was able to connect the watch to my computer and simply drag the application into the “data” folder.
Is there a simple or recommended method to install the application on the Forerunner 955?
Thank you in advance for your support.
Kind regards
  • You still do that, but it's a bit more complicated. What OS is on your computer? Do you see the files on the watch?
  • If you are using macOS, you need a 3rd party app like OpenMTP to manage files on most newer Garmin devices: https://openmtp.ganeshrvel.com/
    If you are using Windows, you can use File Explorer to manage files, same as on older devices (albeit with a few limitations, like not being able to directly create or open files on the device). (e.g. if you want to create a .txt log file to go with your app, you have to create it on a different drive and copy it to the device; you can no longer create such a file directly on the device from file explorer).
    In both cases, you copy the app PRG to the \GARMIN\APPS folder.
    EDIT: either way, you must completely close Garmin Express before attempting to access files on the device. (Including closing the Garmin icon in the Windows notification tray or macOS menu bar.)
  • Thank you for the reply.
    In both systems, if I copy my app into the folder, I still can’t see it on the watch.
    I tried creating a Public subfolder inside GARMIN/Apps, but the result didn’t change.
    In which menu on the watch should I see it?
    From the main menu → start → scroll down → add → applications?
    my file manifest:
    <?xml version="1.0"?>
    <iq:manifest version="3" xmlns:iq="http://www.garmin.com/xml/connectiq">
    <iq:application id="28241861-f84e-4010-9112-682f50f8587f" type="watch-app" name="@Strings.AppName" entry="SoftTimerApp" launcherIcon="@Drawables.LauncherIcon" minApiLevel="1.4.0">
    <iq:products>
    <iq:product id="fr955"/>
    </iq:products>
    <iq:permissions/>
    <iq:languages>
    <iq:language>ita</iq:language>
    </iq:languages>
    <iq:barrels/>
    </iq:application>
    </iq:manifest>
    The application runs correctly on the simulator.
  • In both systems, if I copy my app into the folder, I still can’t see it on the watch.
    Hmm that's strange.
    Note that it's normal for the PRG to disappear from the "file system" after copying it though.
    That's because newer watches will immediately "hide" (move to user-inaccessible storage) any PRGs that are copied to \GARMIN\APPS or installed from the store.
    The fact that the PRG is no longer visible doesn't mean that installation failed.
    As it's a device app, the answer is pretty much yes - it should be in the activities/apps list accessible by pressing START from the watch face. Either it should already be in the list, or you should be able to add it as you described.
    Take a look at \GARMIN\APPS\LOGS\CIQ_LOG.YML. Is there an error similar to "signature check failed"? That could indicate that app installation failed.
    Maybe you have too many CIQ apps installed on the device already? The limit is something low like 20. You can check the limit and the current number of apps installed using the Connect IQ store app on your phone.
  • > I'm sure that in 2036, devs will still be asking why the app PRG disappears immediately after copying it and assuming it means that sideloading failed, and Garmin will happily leave the explanation to forum users.
    If Garmin will still exist in 2036, then it'll be a pretty good proof of the strategy of abandoning CIQ devs.
  • Hi
    Thanks for providing the log folder path: \GARMIN\APPS\LOGS
    However, I keep getting the same error. I tried updating the manifest file with the correct category and product, but it didn’t help. Even after recompiling and generating a new executable, the error persists.
    java -Xms1g -Dfile.encoding=UTF-8 -jar "***/bin/monkeybrains.jar" -o bin/SoftTimer.prg -f /**/SoftTimer/monkey.jungle -y /**/SoftTimer/developer_key
    BUILD SUCCESSFUL
    java -Xms1g -Dfile.encoding=UTF-8 -Dapple.awt.UIElement=true -jar "/**/bin/monkeybrains.jar" -o bin/SoftTimer.prg -f /**/SoftTimer/monkey.jungle -y /**/developer_key
    ERROR: Invalid device id found in the application manifest: 'fr955'.
    ERROR: Invalid device id found.
    java -Xms1g -Dfile.encoding=UTF-8 -Dapple.awt.UIElement=true -jar "/**/bin/monkeybrains.jar" -o /**/SoftTimer/bin/SoftTimer.prg -f /**/SoftTimer/monkey.jungle -y /**/SoftTimer/developer_key -d fr955 -w -r
    WARNING: fr955: /**n/SoftTimer/source/DueView.mc:34,8: Cannot determine if container access is using container type
    BUILD SUCCESSFUL
    Help me!!!!
  • Error: 'Signature check failed on file: SoftTimer'
    Time: 2026-01-24T12:42:54Z
    Part-Number: 006-B4024-00
    Firmware-Version: '27.09'
    Language-Code: ita
  • Stop using AI and start developing in the officially supported tools, namely VSCode. Then follow the steps in the HOWTOs, download the devices you're intertested in from the SDK manager, then edit your manifest.xml from VSCode, and it should all be OK.
    Also it's worth to start opening one of the sample apps and run that in the simulator (or even on your real device), then start modifying it (or use Cmd+Shift+P > Monkey C: New project)
  • Damn artificial intelligence.
    I followed the indicated steps, I installed the correct device, but I can’t get it to work.
    With the previous Forerunner 235, I had no installation problems at all.
  • Which SDK are you using? I see that your FR955 firmware is up-to-date, which means you must build with SDK 7.4.3 or later for sideloads to work, as per:
     Connect IQ SDK 8.2 Now Available
    (According to the same post, you must build with SDK 8.1 or later to upload apps to the store.)
    I'm guessing you probably are using a later SDK, given that 7.4.3 is pretty old by now, but just double-checking.
