forums.garmin.com/showthread.php
o A Descriptive Title (i.e. “Simulator Freezes Launching App in Eclipse”)
FR230: holding menu button triggers onPreviousPage and then onMenu.
o The Environment:-Operating System or Device (including OS number or Software version of device
FR230 fw 7.10
-Eclipse Version
Mars (W10x64)
o A detailed description of the issue
When I long press up key and expect only onMenu to happen, I receive two callbacks in sequence: first onPreviousPage and then onMenu. This happens only on watch, in simulator everything works fine.
o Steps to reproduce the issue
- long press up key
- check that two callbacks are received: first onPreviousPage and then onMenu
o Any applicable additional information
o A code sample that can reproduce the issue (in email only if preferred)
MenuTest example provided with SDK 2.2.1
