Hi everyone,
I'm working on an app that requires high-frequency sensor data logging for sports analysis (specifically, my goal is badminton stroke detection). I have encountered a significant and specific issue related to the Garmin vivoactive 5 watch.
The Issue
I am attempting to record and access Accelerometer and Gyroscope data using the SensorLogger class, and confirming the data stream using Sensor.registerSensorDataListener.
On the vivoactive 5, the Gyroscope data stream is consistently unavailable, returning null in the sensorData callback, while the Accelerometer data is always delivered successfully.
Key Observation (Cross-Device Test)
To rule out code errors, I used the Connect IQ simulator across multiple generations of the vívoactive line for a direct comparison, yielding the following results:
vivoactive 4: Accelerometer data stream works. Gyroscope data stream works.
vivoactive 5: Accelerometer data stream works. Gyroscope data stream FAILS / returns NULL.
vivoactive 6: Accelerometer data stream works. Gyroscope data stream works.
This strongly suggests an issue specific to the vivoactive 5 firmware or its sensor hub driver implementation that is preventing high-frequency Gyroscope data from being exposed to third-party CIQ apps, even though the sensor is physically present on the device.
The Test Code Used
import Toybox.Sensor;
class TestLogger
private var _samplesX = null;
private var _sampleGyroX = null;
public function enableAccel() as Void {
// var maxSampleRate = Sensor.getMaxSampleRate();
var options = {
:period => 1,
:accelerometer => {
:enabled => true,
:sampleRate => 25
:gyroscope => {
:enabled => true,
:sampleRate => 25
try {
Sensor.registerSensorDataListener(method(:accelHistoryCallback), options);
catch(e) {
System.println(e.getErrorMessage());
System.println( "TestLogger started success." );
public function accelHistoryCallback(sensorData as SensorData) as Void {
if (sensorData.accelerometerData != null) {
_samplesX = sensorData.accelerometerData.x;
System.println("Raw samples, X axis: " + _samplesX);
} else {
System.println("Accelerometer Data is NULL.");
if (sensorData.gyroscopeData != null) {
_sampleGyroX = sensorData.gyroscopeData.x;
System.println("Raw samples Gyro, X axis: " + _sampleGyroX);
} else {
System.println("Gyroscope Data is NULL. Cannot be accessed.");
public function disableAccel() as Void {
Sensor.unregisterSensorDataListener();
Request for Resolution
Could the Garmin team please confirm if the high-frequency Gyroscope data stream is intentionally restricted on the vivoactive 5 for Connect IQ applications (API Gating) ?
Thank you for your time and assistance.
