IQ iOS application stops responding after some time, how to keep it alive ?
I have iOS application which provides data for my watchface. The watch face has a very simple flow that periodically requests new data.
My implementation of iOS is based on official example.
This is basically core of my application. It handles connection and sending/receiving messages.
import Combine
import UIKit
import ConnectIQ
import Foundation
final class GarminService {
    // This must match the value in `Info.plist`.
    private static let urlScheme = "com.lukas.garmincompanion"
    static let shared = GarminService()
    private let manager = Manager()
    private let messageSubject = PassthroughSubject<Any, Never>()
    private var lifetimeCancellables: Set<AnyCancellable> = []
    private init() {
        ConnectIQ.shared?.initialize(
            withUrlScheme: Self.urlScheme,
            uiOverrideDelegate: nil
        DeviceManager.shared.restoreDevicesFromFileSystem()
        registerForStoredDevices()
        manager.messageHandler = { [weak self] messageData in
            self?.messageSubject.send(messageData)
            Task {
                let data = await CalendarReader.shared.prepareJsonData()
                print("recevied data")
                await self?.broadcast(dto: data!)
    func observeMessages() -> AnyPublisher<Any, Never> {
        messageSubject.eraseToAnyPublisher()
    @discardableResult
    func handle(url: URL) -> Bool {
        guard url.scheme == Self.urlScheme,
            let devices = ConnectIQ.shared?.parseDeviceSelectionResponse(
            ) as? [IQDevice]
        else { return false }
        DeviceManager.shared.saveDevicesToFileSystem(devices)
        return true
    private func registerForStoredDevices() {
        for device in DeviceManager.shared.savedDevices {
            ConnectIQ.shared?.register(forDeviceEvents: device, delegate: manager)
    func broadcast(dto: Any) async {
        await manager.broadcast(dto: dto)
extension GarminService {
    fileprivate final class Manager: NSObject, IQDeviceEventDelegate,
        IQAppMessageDelegate
        private static let watchAppUuid = UUID(
            uuidString: "xxx"
        @Published
        private(set) var apps: [UUID: IQApp] = [:]
        var messageHandler: ((Any) -> Void)?
        func deviceStatusChanged(_ device: IQDevice!, status: IQDeviceStatus) {
            switch status {
            case .connected:
                let app = IQApp(
                    uuid: Self.watchAppUuid,
                    store: nil,
                    device: device
                apps[device.uuid] = app
                ConnectIQ.shared?.register(forAppMessages: app, delegate: self)
                // IMPORTANT: Sending a message right after connecting sends the messages to the void.
                // I have no idea why it doesn't work, but feel free to shrink the delay. I've found that 100ms works reliably.
                DispatchQueue.main.asyncAfter(deadline: .now() + 0.1) {
                    ConnectIQ.shared?.sendMessage(
                        "Hello there.",
                        to: app,
                        progress: nil,
                        completion: {
                            print($0)
            case .bluetoothNotReady, .invalidDevice, .notConnected, .notFound:
                apps.removeValue(forKey: device.uuid)
            @unknown default:
                print("Unhandled case '\(status.rawValue)'.")
        func receivedMessage(_ message: Any!, from app: IQApp!) {
            print(
                "Received message from ConnectIQ: \(message.debugDescription)"
            guard let message else { return }
            messageHandler?(message)
            let wrapped = NSDictionary(dictionary: ["message": dto])
            for app in apps.values {
                await ConnectIQ.shared?.sendMessage(
                    wrapped,
                    to: app,
                    progress: nil
                print("Sent \(wrapped) to \(app)")
//        deinit {
//            ConnectIQ.shared?.unregister(forAllDeviceEvents: self)
//            ConnectIQ.shared?.unregister(forAllAppMessages: self)
extension ConnectIQ {
    static var shared: ConnectIQ? {
        sharedInstance()
Everything works perfectly for about one or two hours. After that, the iOS application suspends and stops responding. I have to start it manually and redirect to the Garmin Connect application again.
I have Background fetch, Background processing and Uses bluetooth LE accessories enabled.
I did not find a way how to keep connection with my watches alive for a long time like with Garmin connect app. Does anyone have experience with that?
Thanks
