I have a project which uses multiple project files. A virtual base class project with multiple concrete projects which make use of the base class. I get the following compiler warning when building the projects.
"A valid 'project.manifest' property was not defined within a jungle file."
The project compiles and all is well with the binary image.
Which relates to the fact I have no project manifest declared in the Base Class project Jungle file. However if I declare a Project Manifest with
project.manifest = manifest.xml
"Attempting to reset project property 'manifest'." as I also have a jungle file in the sub projects, and this is where I need them.
Any tips on what do I need to do to plicate the compiler so I do not get any warnings or errors?
