ERROR CIQ Simulator - sdk 8.2.1 - device fr55 -
HI,
I am trying a data field for my Forerunner 55 and when I try to test the app I return the following error:
Error: Unexpected Type Error
Details: Failed to start CIQ Application
Stack:
Encountered app crash.
Someone can tell me what I can do to solve this situation.
Thank you all
Greetings
Riccardo
  • If you run the data field on a devices with more memory, what is the peak memory usage?  Does it exceed the fr255's tiny data field memory?
  • The date Field I was trying to make for FR55 I wanted to show the active calories, but when testing, the execution of the crash application and does nothing. I don't know what the peak memory consumption corresponds and I don't even know this size as a measure. In any case, I discovered that higher band watch, they display active calories by selecting them from the menu
    Thanks anyway for your intervention
