SDK manager does not show the SDKs
Hi,
is there currently a problem with the SDK manager? Eclipse's SDK manager does not show any SDK in the list although there have to be some.
If I retrieve the SDK list directly after starting Eclipse I get following failure message: "SDK MANAGER: Problem getting available SDKs."
Any hints on that?
    Hi,
    Any hints on that?
    Hey topcaser,
    Do you know if you have the latest version of the Eclipse Plugin installed. I'm not seeing the same thing over here. Also, are you using Windows? Mac? What OS? Do you know if your Connect IQ preferences are pointed at the SDK directory?
    Thanks so much,
    Coleman
  • Hi Coleman,
    I use windows. Nevertheless, you pointed me in the right direction. I did reinstall the plugin and now it works again. Maybe it has something to do with my last bluescreen....
    Thanks so much for your help.
    Hi Coleman,
    No problem at all. I'm glad to hear that it's working again.
    -Coleman
