Monkey C: Verify Installation fails with "Error getting initialization options from client"
I'm unable to use the "Monkey C: Verify Installation" command in Visual Studio Code. It consistently fails with the following error:
Error getting initialization options from client.
This happens regardless of:
  • SDK version (tested: 8.1.1, 6.4.2)
  • Java version (tested: Java 8 and Java 11, Temurin and Zulu distributions)
SDKs are correctly installed via Garmin SDK Manager. Java path is correctly set in settings.json. The error occurs immediately and no further logs are shown.
Please advise if this is a known issue or if the extension is no longer compatible with current SDKs.
