Hi all,
one of the biggest reasons because I bought a FR630 is that it has an built-in metronome.
That's cool, if I could hear it.
I cannot hear the metronome, breathing, cars noise, and wind always cover the metronome, so I cannot hear it, the sound is too low.
So, because I am a developer I have been trying to find some workarounds:
1. Datafield which calls every XXXms Attention.playSound(), passing a tone value louder than the default one, unfortunately the datafield cannot use the timer, so I cannot trigger anything more often than 1 second ( the onUpdate() method is called once every second not more often). So, it looks like that this solution is not viable.
2. Watch app, from  a watch app I can call Timer.start(callback, milliseconds, repeat), and then in the callback function I play a loud sound, but I cannot start the run activity because the app would be stopped in order to start the run activity, while I would like to use the run activity embedded in my FR630, instead to use a custom one.
I do not know how to find a workaround to have a louder metronome beep (sound), I am running out of ideas.
My last idea was to hack the firmware to try to increase the volume, but I am not sure how to do it, and neither if it is feasible.
Do any of you have any idea, basically to increase the volume of the metronome? ( or any workaround?)
Regards,
Dan
