Any way to simulate different compass headings when testing an app?
I'm working on an app the uses "heading" to display different things - in this case, it shows the stars overhead, and so it uses the direction the watch is aimed to determine which part of the sky to show.
var sensorInfo = Sensor.getInfo();
var compassHeading = sensorInfo.heading;
So this all works fine, as a rule. But I've been doing some troubleshooting and have not figured out how to simulate different headings in the simulator. It just always returns heading 0.
Does anyone know how?
I can set lat & lon for the GPS, but not direction or bearing.
In the simulator simulation/navigation data I can set various fields: Bearing, Bearing from Start, and Track.  None of those seem to affect the sensor heading received.
Is this something that can be done with an activity track or similar?
  • Have you tried simulating activity data?
    - From the simulator menu, select Simulation > Activity Data
    - Press the play button in the lower left hand corner of the dialog
    I found that this generates constantly changing, non-0 heading values for both Sensor.getInfo() and Position.getInfo().
    You can also use the activity data dialog to play sensor data from a FIT file.
    I think those settings only affect the corresponding fields in Activity.Info, returned by Activity.getActivityInfo().
