Issues with SDK 8.1.x and glance on Fenix 6
I have issues with getting my glance to run with Fenix 6 on SDK 8.1.x.
On SDK 7.4.3 everything works as it should, code builds and glance is shown.
On SDK 8.1.0, I get the following error when building:
 *  Executing task: monkeyc: Building For Device
java -Xms1g -Dfile.encoding=UTF-8 -Dapple.awt.UIElement=true -jar c:\Users\Robert\AppData\Roaming\Garmin\ConnectIQ\Sdks\connectiq-sdk-win-8.1.0-2025-03-04-7ae1ed1cb\bin\monkeybrains.jar -o bin\evccgarmin.prg -f d:\Projects\evcc-garmin\evcc-garmin\monkey.jungle -y d:\Projects\evcc-garmin\ciq-developer-key\developer_key -d fenix6_sim -w
ERROR: null
On SDK 8.1.1 the build works again, but getGlanceView() is not called, instead it goes directly into getInitialView(). Glance Launch Mode is set to Launch in Glance Mode.
If I run the same configuration on a Fenix 6 Pro, the glance works with all three SDK versions.
What do you guys think, is this a bug, or am I missing something else?
