Help find my bug: on device settings
Oke, I got the on device settings to work in collaboration with the off device settings. Thanks for helping me in the right directions.
I only still have one strange behaviour. If back from my main menu is triggered with a swipe to right everything works perfect (at least imho :D ) however, if the back button is used, it shows a black screen and needs to be pressed again. Actually I'd expect both to return to the Garmin generated Settings/Delete menu, but that is gone. So I guess that has to do with third party watchfaces, or can I manipulate the Settings/Delete menu as well oops that's another question. From my menu's submenu's the backbutton works as expected.
The need to press the back button twice bothers me, so please tell me how to fix that, if it can be fixed.
It makes no difference if I override the onBack() function in the delegate or not.
   public function onBack() as Boolean {
        WatchUi.popView(WatchUi.SLIDE_DOWN);
        return true;
Top Replies
  • return false in onBack()
    As noted in the op, the bug happens whether or not onBack() is overridden so changing its return value would be unlikely to fix the problem.
    The problem is that there…
All Replies
  • This is for a watchface, right?
    No. But for Fenix 8 and newer watches, you can use the watch's native watchface editor in CIQ. So the user could configure your watchface the same way they configure native watchfaces.
    Which watch are you using?
    I don't see this problem on my FR955, with on-device settings for either data fields or watchfaces.
    Can you try the Simple Lean G2 watchface from jim_m_58? It has on-device settings and it doesn't have that problem on my watch. If it has that problem on your watch, maybe there's a problem with the watch firmware.
  • Yes, for a watchface.
    The back button works fine with Jims Simple Lean G2 watchface.
    So it has something to do with my sourcecode I guess. Without code tags because of error messages.
    class ttrApp extends Application.AppBase {
    private var _mainView;
    public function getSettingsView() as [Views] or [Views, InputDelegates] or Null {
    return [new $.ttrSettingsView(), new $.ttrSettingsDelegate()];
    function onSettingsChanged() { // triggered by settings change in GCM
    _mainView.updateProperties();
    WatchUi.requestUpdate(); // update the view to reflect changes
    var menu=null;
    class ttrSettingsView extends WatchUi.View {
    public function initialize() {
    View.initialize();
    menu = null;
    public function onUpdate(dc as Dc) as Void {
    if (menu == null) {
    menu = new $.ttrSettingsMenu();
    var menudelegate = new $.ttrSettingsMenuDelegate();
    var sublabels;
    var sublabel;
    // Add menu items for demonstrating toggles, checkbox and icon menu items
    if (hasBackgrounds) {
    sublabels = [$.Rez.Strings.none,
    sublabel = loadResource(sublabels[ttrbackgroundvalue+1]);
    menu.addItem(new WatchUi.MenuItem(loadResource($.Rez.Strings.wallpaper), sublabel, :wallpaper, null));
    sublabels = [$.Rez.Strings.hide,
    sublabel = loadResource(sublabels[ttroverrideweeknumber+1]);
    menu.addItem(new WatchUi.MenuItem(loadResource($.Rez.Strings.overrideweeknumber), sublabel, :overrideweeknumber, null));
    sublabel = loadResource(sublabels[ttrwarnings+1]);
    menu.addItem(new WatchUi.MenuItem(loadResource($.Rez.Strings.warnings), sublabel, :warnings, null));
    WatchUi.pushView(menu, menudelegate, WatchUi.SLIDE_IMMEDIATE);
    class ttrSettingsDelegate extends WatchUi.BehaviorDelegate {
    BehaviorDelegate.initialize();
    return true;
  • class ttrSettingsMenu extends WatchUi.Menu2 {
            Menu2.initialize({:title=>loadResource(Rez.Strings.settings)});
    class ttrSettingsMenuDelegate extends WatchUi.Menu2InputDelegate {
            Menu2InputDelegate.initialize();
        public function onSelect(menuItem as MenuItem) as Void {
            var _id = menuItem.getId();
            switch (_id) {
                case :wallpaper :
                    $.pushSubWallpaper();
                    break;
                case :overrideweeknumber :
                    $.pushSubOverrideweeknumber();
                    break;
                case :warnings :
                    $.pushSubwarnings();
                    break;
        public function onBack() as Void {
  • Thanks for posting your code!
    Yeah it's happening because your settings view instantly pushes a 2nd view (the main menu view).
    So the flow is:
    user opens watchface menu > user selects Customize > ttrSettingsView is pushed (by the firmware / getSettingsView) > main menu view is pushed (by your app / ttrSettingsView)
    This explains why the user has to press back twice at your main menu, but not why a single swipe right works. The first press of BACK pops the main menu, and the second press pops trSettingsView.
    To fix this, getSettingsView() should directly return the main menu.
    user opens watchface menu > user selects Customize > main menu view is pushed (by the firmware / getSettingsView)
    You should move all the code from trSettingsView.initialize() to getSettingsView(). Once you've done that, you don't need trSettingsView or ttrSettingsDelegate.
        private
        var _mainView;
        public
        function getSettingsView() as[Views] or[Views, InputDelegates] or Null {
            var menu = new $.ttrSettingsMenu();
            var sublabels;
            var sublabel;
                sublabel = loadResource(sublabels[ttrbackgroundvalue + 1]);
                menu.addItem(new WatchUi.MenuItem(loadResource($.Rez.Strings.wallpaper), sublabel,: wallpaper, null));
            sublabel = loadResource(sublabels[ttroverrideweeknumber + 1]);
            menu.addItem(new WatchUi.MenuItem(loadResource($.Rez.Strings.overrideweeknumber), sublabel,: overrideweeknumber, null));
            sublabel = loadResource(sublabels[ttrwarnings + 1]);
            menu.addItem(new WatchUi.MenuItem(loadResource($.Rez.Strings.warnings), sublabel,: warnings, null));
            return [menu, menudelegate];
  • Thanks, I guess I now understand the problem!
  • It's fixed, thanks again!
  • That toke me to the blue triangle of death.
  • At least in the simulator it did, so I didn't try it on my watch :D
  • in the sim? That means you exited your main view (the las one in the pile of views, or usually the 1st one you opened in getInitialView) On a real device it just exits the app.
