monkey.jungle resourcePath
I would like to use more than 255 strings in my watch face for the more recent watches, but still let the older watches work. So my logic was to specify 2 different resource paths:
resources-standard - over 255 stings
resources-lower - less than 255 strings
(I'll use the Fenix 6 and Fenix 8 Solar 47mm as the 2 examples)
So in the monkey.jungle file I specify:
base.resourcePath = $(base.resourcePath);resources-standard
fenix6.resourcePath = $(fenix6.resourcePath);resources-lower
This is OK for the F8 but errors on the F6 as having too many strings - which surprised me. OK I thought maybe its the order, so I put the F6 first
This also errors.
Now I'm into a world of badness, especially in the future, and I make the resources-lower the base folder
base.resourcePath = $(base.resourcePath);resources-lower
fenix8solar47mm.resourcePath = $(fenix8solar47mm.resourcePath);resources-standard
And this worked correctly for the F6 and F8, the issue this would present is it would require every new watch to be added to the list, instead of it being a one off static list now.
I'm using Windows 11, VSC 1.98.2, Monkey C 1.1.1, SDK 8.1.0 and my devices are up to date.
Am I doing this wrong, is there a better way e.g. specify API level to use different resource folders or somehow do this in code? Any help, guidance or pointers would be much appreciated
Top Replies
All Replies
  • $(fenix6.resourcePath) already includes $(base.resourcePath) so you need:
    fenix6.resourcePath = resources-lower
    This works usually, but if you use other "pre-definied" resource folders (languages, shapes, etc) then you'll need to add all of those to the "low" devices.
  • base.resourcePath = $(base.resourcePath);resources-standard
    Yeah this is the general approach I have taken in the past.
    This is true, except for the part about language folders (I think). As per the generated SDK_ROOT/bin/default.jungle file, language-specific paths are handled separately from resourcePath paths.
    e.g.
    # Set the base properties, base represents the root of the Monkey C Project
    base.sourcePath = .\**.mc
    base.resourcePath = resources
    base.personality = resources
    # Set the base language-specific string resources
    base.lang.hun = resources-hun
    base.lang.nob = resources-nob
    base.lang.swe = resources-swe
    base.lang.dut = resources-dut
    # Set the round family qualifier
    round = $(base)
    round.resourcePath = $(round.resourcePath);resources-round
    round.personality = $(round.personality);resources-round
    # Set the round language-specific string resources
    round.lang.hun = $(round.lang.hun);resources-round-hun
    # Set the round-260x260 family qualifier
    round-260x260 = $(round)
    round-260x260.resourcePath = $(round-260x260.resourcePath);resources-round-260x260
    round-260x260.personality = $(round-260x260.personality);resources-round-260x260
    # Set the round-260x260 language-specific string resources
    round-260x260.lang.hun = $(round-260x260.lang.hun);resources-round-260x260-hun
    # Set the fr955 family qualifier
    fr955 = $(round-260x260)
    fr955.resourcePath = $(fr955.resourcePath);resources-fr955
    fr955.personality = $(fr955.personality);$(devicesPath)\fr955;resources-fr955
    # Set the fr955 language-specific string resources
    fr955.lang.ara = $(fr955.lang.ara);resources-fr955-ara
    fr955.lang.bul = $(fr955.lang.bul);resources-fr955-bul
    So for example, if I override fr955.resourcePath as follows, fr955.lang.* should still be unchanged:
    fr955.resourcePath = resources-random # base.resourcePath is no longer included
    Personally I find that looking at default.jungle really helped me to understand how the resource/language qualifier system works. (e.g. you can see how base inheritance works by following one of the chains: e.g. base > round > round-260x260 > fr955)
  • Excellent that worked - thank you both.
    For completeness, I needed to add drawables, fonts etc.. into the resources-lower
