return 404 when using Communications.makeImageRequest with this url https://tile.openstreetmap.org/15/16924/11672.png
Hello.
I try to get an url with an application and get 404.
It's not possible to view Http traffic logs  and I don't know why I cant' see it.
When I move this picture to my web server   https://riedid74.fr/15/16924/11672.png
all is good and I display the picture correctly  on the watch.
Is it a restriction to get a picture from  tile.openstreetmap.org
thanks
the code is
        var options = {
           // :palette => [ Graphics.COLOR_WHITE,                     // set the palette
           //              Graphics.COLOR_BLACK ],
            :maxWidth => 256,
            :maxHeight => 256,
            :method => Communications.HTTP_REQUEST_METHOD_PUT as Communications.HttpRequestMethod,
            :responseType => Communications.HTTP_RESPONSE_CONTENT_TYPE_TEXT_PLAIN as Communications.HttpResponseContentType,
            :dithering => Communications.IMAGE_DITHERING_FLOYD_STEINBERG,
            :packingFormat => Communications.PACKING_FORMAT_PNG
        // Make the image request
        Communications.makeImageRequest(url, parameters, options, self.method(:onReceiveImage));
function onReceiveImage(responseCode, data) {
      System.println("function onReceiveImage  response="+ responseCode+ "\n"+data);
         if (responseCode == 200) {
            image = data;
        } else {
            image = null;
            image = data;
  • PHP is passing the header from the calling server to any gets it makes using file_get_contents.
    Turns out if I use curl_exec instead I have more control of the headers, and it appears to be picky.
    Just using "Mozilla/5.0" gets a 418 blocked error, but with a whole bogus browser string like "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:15.0) Gecko/20100101 Firefox/15.0.1" it works.
    Back to the OP's problem unless all calls to makeImageRequest go through another server first to clean up the user agent this looks like yet another "won't fix" from Garmin.
  • That's not what I meant. I was asking if passing a "User-Agent: Foo" header to makeImageRequest is that used when the Garmin server makes the request to the requested url. However now I realized that it doesn't even has an ability to pass headers. Only makeWebRequest has that feature. Still the question is still valid for that method (though only as a curiosity now)
  • However now I realized that it doesn't even has an ability to pass headers
    Someone could submit an enhancement request. I can't get garmin to fix bugs I find, so it should be someone else with a good track record with these.
  • LOL. I don't think such person exists in this forum. But even if they would add it, it'll probably be only added to the newer devices.
  • This is a very bad behavior.  I have recently started experiencing the dreaded 404 error using makeImageRequest and it just started in the past few weeks.  The interesting thing is, I can make it work in the simulator if I do a test build with an old SDK.  See more details in this post.
    https://forums.garmin.com/developer/connect-iq/f/discussion/413866/also-getting-error-404-with-makeimagerequest--/1956909#1956909
    Very frustrating.  Same server, same code, just an SDK change and old (4.0.6) works, new (8.2.2) does not.  Seems 6.2.2 and above all share the same problem.
