The subject summarises my question.
Background info: - I have an idea for an app I want to develop and add to the Edge 1050 Widget Loop (https://www8.garmin.com/manuals/webhelp/GUID-08ACA9FC-DEE6-4C8D-8A95-F62181C512E9/EN-US/GUID-8932D61A-C839-4704-BB71-3C2383B43A54.html) and I can't get it done.
I started by coding a simple boiler plate App, and sideloaded it to my Edge 1050.
It appears as a menu item in the Connect IQ menu.
When I open the Connect IQ store app my sideloaded app appears in the list of 'installed' apps.
The app itself workls perfectly when launched from the 'Connect IQ' menu.
I added a Glance View to the app and it appears in the glances list.
It works perfectly when launched from its Glance.
So, the app is technically OK in every aspect.
It's size is about 16k so that can't be an issue.
I tried building the app as type widget as well as type App, but that makes no difference.
No matter what I tried it does NOT appear in the list of apps in the 'System/Widgets/+' menu.
And that is what I want.
Glances require you to go back to the home screen first, while widgets can be called just bij sweeping down wherever you are on the UI.
Is there maybe something I overlooked, some setting I must change to enable my app on the widget loop?
Hopefully someone here can give me a clue, or maybe someone from Garmin can help me out.
Any help is appreciated.
