Why is the Garmin Fenix 7x Pro unable to detect when it is removed from the wrist? So many uses for this feature, especially with technology already there in the watch.
The way Garmin Pay does it, is by watching the OHR. If the watch is removed you need to re-enter the pin.
With something like this
newHr will be null if the watch isn't being worn.
This means you need to keep OHR turned on (24/7 mode is fine - the leds flash if you peek under it). I've also found that with some devices, if you take off the watch and lay it flat on something the a shiny white surface, that can fool the OHR, so watch for that.
