Hi all,
I am developing a simple data field that rotates between vitals derived from a mixture of custom and conventional ANT+ profiles. I have managed to do that successfully using an ANT+ dongle and the simulator. However, I am a little stuck after sideloading the app to the actual device - Garmin Edge 520.
Specifically, in the Eclipse environment, I went under Connect IQ > Build for Device Wizard. After filling in the project name, and device, and the output directory as '..\Garmin\Apps', I was able to find the generated binary in the Apps folder (.prg extension). After doing this, I tried various settings on the 520 to try to load it, but just can't find it (for published datafields, this comes up as a option under activity profiles, but not so in this case). Can anyone advise in terms of what to do in order to load the prg file?
Many thanks,
Ed
