Hi all,
I'm doing my once a year update to my one and only app, and as is the case pretty much every time, my environment is utterly broken after updating the SDK :)
I'm seeing `Unable to load private key: ~/ConnectIQ-SDK/developer_key.der (No such file or directory)` when I try to run my app in the simulator (or build, or any other command) but this file absolutely does exist. In fact I can copy the output command line and run it in a separate terminal and it works (I just have to wrap quotes around the jar file in the path for this). However the command doesn't launch the simulator when I do that, so I can't run in the simulator at all now. Grateful for any help.
-William
