Handling HTTPS/SSL in makeJsonRequest
Hi all,
Background:
I am the developer of the GarminFhem widget, which uses HTTP requests to control the Fhem home automation system. Using a standard web browser, I can submit such request via HTTP and via HTTPS. My personal Fhem installation uses certificates that I created locally on my own for HTTPS. Therefore, the common web browsers cannot verify my certificates and I have to confirm in popups in Safari/Chrome/etc. that I am still trusting my own certificates, which I usually do :-).
Issue:
Now I would love to send the requests from my GarminFhem widget to my Fhem installation via HTTPS. In the simulator, it works, but on the watch, I get a timeout when sending the makeJsonRequest (NETWORK_REQUEST_TIMED_OUT = -300). My guess is that it is because the GarminConnect App on my iPhone, which eventually sends out the requests to my Fhem system, does not trust the certificate.
Question:
  • Can anyone confirm my guess?
  • Does anyone have an idea how I can make the GarminConnect trust my certificate?
  • Does anyone know how to get more debug information than the return code from the json call?
  • Any other hints?
Thanks a lot & best regards,
Florian
    I believe that the best way would be to get a trusted certificate authority to sign your certificate. Your certificate will be trusted if it is signed by a trusted certificate authority. You should be able to get a certificate for free these days...
    https://www.sslforfree.com
    https://letsencrypt.org
    https://gethttpsforfree.com
    The advantage of this is that the certificate should work with any browser you point at it.
    If you don't care to get a certificate that is signed by a signing authority, you can install the certificate onto your devices. On iOS, you can e-mail your self-signed certificate to yourself and then opening the attachment. I'm sure you can do this on android, but I'm not sure if the process is the same. A google search about installing ssl certificates on your device should help.
    No, not really. The system is a black box.
  • Hi Travis,
    once more: A big thank you for your prompt and helpful reply.
    I got it working now via sslforfree.com. I have already tried it a couple of weeks ago with letsencrypt, but it did not work because I am using a subdomain of a domain that I dont own (I only "own" the subdomain). With "SSL for Free", I got a certificate etc. and it is working - I can now access my home automation system via HTTPS :D
    But, there is another new issue: Though the HTTPS requests that I sent from my watch are received by my home automation system and the intended command is executed successfully, makeJsonRequest returns -300, i. e. NETWORK_REQUEST_TIMED_OUT. That means my watch now displays an error message and I have no confirmation on the watch that the command was executed successfully.
    Does anyone have similar experiences, i. e. https calls are actually transmitted properly, but makeJsonRequest returns a timeout?
    Here is my code:
    function callFhem(command)
    //TODO Test SSL again when proper SSL setup
    if (!self.communicationOngoing)
    communicationOngoing = true;
    MessageContainer.getInstance().setPermanentMessage( Ui.loadResource(Rez.Strings.message_processing) );
    Comm.makeJsonRequest(
    FhemPropertiesHandler.getFhemUrl(),
    { "cmd" => command },
    buildOptions(),
    method(:onReceiveJsonResponse));
    FhemDebugUtils.logInfo("Request Sent:" + command);
    function buildOptions()
    if (FhemPropertiesHandler.isFhemAuthenticationRequired() == true)
    var authenticationStringEncoded = getAuthenticationStringEncoded();
    var headers = {"Content-Type" => Comm.REQUEST_CONTENT_TYPE_URL_ENCODED};
    headers.put("Authorization", Lang.format("Basic $1$", [authenticationStringEncoded]));
    var options = { :method => Comm.HTTP_REQUEST_METHOD_GET,
    :headers => headers};
    return options;
    else
    return null;
    Unfortunately, this did not work for me. I have tried it before I got the certificates from SSL for Free. After I installed my self-signed certificate on my iPhone, I could work with my home automation system without warnings in Safari, but the makeJsonRequest calls still returned an error (also a timeout :-)). Anyway, it is strange, but I won't follow up here because the new certificates from SSL for Free a way better solution in my eyes.
