Is this normal?
I make a change to a barrel, and I compile it to the folder to which my Field's barrels,jungle points.
Now I make changes to my field, and I run it. But it does NOT use the current barrel.
What I have to do is go into the field's manifest.xml file, and remove the Barrel Dependency and re-add the Barrel.
Now when I run the field, it does use the updated Barrel.
I assume the same steps are needed to ensure the field's PRG file is also using the updated Barrel before publishing?
I don't recall this being needed in Eclipse, but I'm using VSC now.
