Possibly a dumb question, but search yielded no results ("toggle app settings" is greyed out, and this is a datafield). I've set up a datafield - both a basic one (from scratch for troubleshooting) and one that's available in github (this is the manual). I can see the data outputs, but the datafields are changeable, and the only button that seems to create any sort of response is the top right button (which for this, is an activity datafield, so I get to see the timer only). Highly recommended btw!
Is it not possible to customize the datafield on the simulator? I can't do so on the watch, because once I build the PRG and install it, it seems to just be flashing which indicates I still have some tweaking to do, so I'm trying to isolate the problem on the simulator before going that route again. Plus, it seems I can't interact with my watch while it's charging and plugged into a computer? (Is that new? I usually never really charge on a computer and I know I can interact with the watch during those other times...)
Trying to make a nicer version for the 8, as latest publicly availalbe code supports a 416x416 watchface. The main screen is finally looking good on my 454x454, I just know something's broken somewhere when making changes to the data field and switching things up. I would love to not keep going back and forth with configuring it and sticking it on my device - there's gotta be a way to do this on the sim, right? I restored an older version not including my changes and loaded a 280x280 - the display was fine, but again, I couldn't figure out how to tweak the datafield.
Thanks!
