Bug with IF statement??
Really need some help to understand what's going on here.
var stepProgress = (ActivityMonitor.getInfo().steps*1.0)/(ActivityMonitor.getInfo().stepGoal*1.0);
if (stepProgress > 1) {
System.println( "Do something");
else {
System.println("stepProgress < 1 - Value:" + Math.ceil(stepProgress));
System.println("Step Progress: "+stepProgress.toString() );
Even when stepProgress takes the value of 1.03, 2.3, 3.5, 4, etc. is always executing the "else" code. Why???
Any ideas?
    More info
    Here is the console debug output:
    stepProgress < 1 - Value:3.000000
    Step Progress: 2.588000
    Step Progress: 2.628000
    Step Progress: 2.668000
    Step Progress: 2.708000
    Step Progress: 2.748200
  • What happens if you have:
    if (stepProgress >1.0) {
    Thanks for your answer. Still going to the "else" code.
    More info:
    The code is in the "draw" function of a Drawable class.
    Also tried with:
    if (1.0 < stepProgress)
    After restarting simulator & eclipse, same error.
  • I haven't done anything with widgets, but was just playing around a bit.
    I took the ActivityTracker sample widget and added in the following code.
    // Handle the update event
    function onUpdate(dc) {
    dc.setColor(Gfx.COLOR_BLACK, Gfx.COLOR_BLACK);
    dc.clear();
    // Insert Code from Here...
    var stepProgress = 0;
    Sys.println("stepProgress: " + stepProgress);
    if (3.0>1.0) {
    Sys.println("Doing Something");
    // ...to here
    var info = Act.getInfo();
    This produced the following output.
    stepProgress: 0
    Doing Something
    Then if I just change the var stepProgress line to the following
    var stepProgress = (Act.getInfo().steps*1.0)/(Act.getInfo().stepGoal*1.0);
    if (3.0>1.0) {
    // ...to here
    This produced the following output. (It's not going inside the If statement like I would expect)
    stepProgress: 0.000000
    It seems to not like floats with >, <, >=, or <= after that var stepProgress line of code.
    It works correctly if I made the following change.
    if ((3.0).toNumber()>(1.0).toNumber()) {
    // ...to here
    This makes the output below like I'd expect.
    Doing Something
    Incidentally, the following code seems to work like I'd expect.
    var stepProgress = (info.steps.toFloat() / info.stepGoal.toFloat());
    if (3.0>1.0) {
    // ...to here
    I was just playing around with this. It's not clear to me why it's acting like this. It seems like something is getting stepped on in the background when 2 getInfo() calls are made in the same line. Sorry if I've just added confusion, but I thought maybe some of this would be helpful. It does smell like there's a bug somewhere here.
    wow
    Sir, thanks a lot for taking the time of doing those tests.
    It's certainly a bug, I changed my code to the following (as you suggested):
    var actInfo = ActivityMonitor.getInfo();
    var stepProgress = (actInfo.steps*1.0)/(actInfo.stepGoal*1.0);
    if (stepProgress > 1.0 ) {
    And now it works as expected.
    It would be great if someone on Garmin can take a look on this.
    Regards.
  • Good catch dude. This is interesting. If you use this test code, the problem still occurs...
    var stepProgress = ActivityMonitor.getInfo().steps;
    //Sys.println(stepProgress);
    var stepGoal = ActivityMonitor.getInfo().stepGoal;
    //Sys.println(stepGoal);
    stepProgress = (stepProgress * 1.0) / stepGoal; // this line is special
    if (stepProgress > 1.0) {
    and disassemble it (by compiling with -g), you see this (emphasis mine)...
    # stepProgress=(stepProgress*1.0)/stepGoal;
    source_TestApp_mc_22_8:
    lgetv 2
    fpush 1.0
    mulv
    lgetv 3
    divv
    lputv 2
    If you change the floating-point constant to double precision...
    stepProgress = (stepProgress * 1.0d) / stepGoal; // this line is special
    The only change in the assembly is this...
    lgetv 2
    dpush 1.0
    mulv
    This code works.
    I'm not sure what is happening, but it looks like the correct opcodes are being generated, but the instructions themselves (probably the gt instruction, or maybe bf) is just misbehaving (i.e., it seems that this is a vm bug and not a compiler bug).
    source_TestApp_mc_24_8_if:
    lgetv 2
    fpush 1.0
    gt
    bf @source_TestApp_mc_24_8_else
    source_TestApp_mc_24_32_start:
    Travis
  • This is a weird one! Looking at the code I sure didn't see anything.
    Another simple work around would be to use this for the if statement (no floats or doubles involved):
    if(Act.getInfo().steps>Act.getInfo().stepGoal) {
    Hey everyone. Thanks for the heads up. I was also able to reproduce this. I've started a ticket for this to be looked at.
    Thanks,
    Coleman
    Cool, didn't know that flag.
