Why does my app skip some seconds ?
Hello,
I've built a beta app only tested on my Edge 520Plus device.
It's working well except that, every 5 to 6 seconds, my app isn't refreshed on my device after starting an activity.
I noticed this because every 5 or 6 seconds, a second (timer.Time) isn't displayed.
I was wondering if my counter (compteur) was the cause, so I tested it and noticed that it faced the same issue simultaneously with the timer.
So what ? Am I asking for too many calculation to my device ? Did you faced similar issue ?
Just as an information, every 5mn (counter = 299) the counter is reset to zero because from counter = 294 to 299, averages values are displayed instead of live values.
Here's the code of the View. Thanks in advance for your hints !
import Toybox.Activity;
import Toybox.Graphics;
import Toybox.Lang;
import Toybox.WatchUi;
import Toybox.Time;
import Toybox.Math;
class projView extends WatchUi.DataField {
   hidden var mHR as Numeric;
   hidden var mHRMoy as Numeric;
   hidden var mDistance as Numeric;
   hidden var mDistKM as Numeric;
   hidden var mSpeed as Numeric;
   hidden var mCad as Numeric;
   hidden var mCadMoy as Numeric;
   hidden var mPW as Numeric;
   hidden var mPW1 as Numeric;
   hidden var mPW2 as Numeric;
   hidden var mPW3 as Numeric;
   hidden var mPW4 as Numeric;
   var mClimb as Numeric;
   hidden var mAlt1 as Numeric;
   hidden var mAlt2 as Numeric;
   hidden var mAltInt1 as Numeric;
   hidden var mAltInt2 as Numeric;
   hidden var mSlop as Numeric;
   hidden var mTime as Numeric;
   hidden var mTimeSec as Numeric;
   hidden var mDuree;
   hidden var horloge;
   hidden var horloge_text;
   hidden var batt;
   hidden var batt_stat;
   hidden var batt_text;
   var compteur as Numeric;
   hidden var reset_valeur as Numeric;
   hidden var previous_time as Numeric;
   hidden var vitesseMoyenne as Numeric;
   hidden var timeArrondi as Numeric;
    function initialize() {
        DataField.initialize();
        mHR= 0d;
        mHRMoy = 0d;
        mDistance = 0d;
        mDistKM = 0.00f;
        mSpeed = 0.0f;
        mCad =0d;
        mCadMoy=0d;
        mClimb = 0d;
        mAlt1 = -999d;
        mAlt2 = 0d;
        mAltInt1 = 0d;
        mAltInt2 = 0d;
        batt = 0d;
        mSlop = 0f;
        mTime = 0d;
        mTimeSec = 0d;
        previous_time = 0d;
        mPW = 0d;
        mPW1 = 0d;
        mPW2 = 0d;
        mPW3 = 0d;
        mPW4 = 0d;
        compteur = 0d;
        vitesseMoyenne = 0.0f;
        reset_valeur = 299;
        timeArrondi = 0.00f;
        mDuree="00:00:00";
    // Set your layout here. Anytime the size of obscurity of
    // the draw context is changed this will be called.
    function onLayout(dc as Dc) as Void {
 //       var obscurityFlags = DataField.getObscurityFlags();
            View.setLayout(Rez.Layouts.MainLayout(dc));
            var hrlbl = View.findDrawableById("hr_lbl") as Text;
            hrlbl.locY =  7 ;
            hrlbl.locX =  40 ;
            var hrval= View.findDrawableById("hr_val") as Text;
            hrval.locY = hrlbl.locY + 15 ;
            hrval.locX = 60;
            var pwlbl = View.findDrawableById("pw_lbl") as Text;
            pwlbl.locY =  hrlbl.locY  ;
            pwlbl.locX =  140;
            var pwval= View.findDrawableById("pw_val") as Text;
            pwval.locY = hrval.locY  ;
            pwval.locX = 175;
            var vitlbl= View.findDrawableById("vit_lbl") as Text;
            vitlbl.locY = hrlbl.locY + 55;
            vitlbl.locX = 100;
            var vitval = View.findDrawableById("vit_val") as Text;
            vitval.locY = vitlbl.locY  + 20;
            vitval.locX = 95;
            var distlbl = View.findDrawableById("dist_lbl") as Text;
            distlbl.locY =  vitlbl.locY +70;
            distlbl.locX =  55;
            var distval= View.findDrawableById("dist_val") as Text;
            distval.locY = distlbl.locY + 15;
            distval.locX = 55 ;
            var cadlbl = View.findDrawableById("cad_lbl") as Text;
            cadlbl.locY =  distlbl.locY ;
            cadlbl.locX =  155;
            var cadval= View.findDrawableById("cad_val") as Text;
            cadval.locY = distval.locY ;
            cadval.locX = 180;
            var timelbl = View.findDrawableById("time_lbl") as Text;
            timelbl.locY =  distval.locY +40;
            timelbl.locX =  55 ;
            var timeval= View.findDrawableById("time_val") as Text;
            timeval.locY = timelbl.locY + 15;
            timeval.locX = 55 ;
            var climblbl = View.findDrawableById("climb_lbl") as Text;
            climblbl.locY =  timelbl.locY;
            climblbl.locX =  155;
            var climbval= View.findDrawableById("climb_val") as Text;
            climbval.locY = timeval.locY ;
            climbval.locX = 185 ;
            var horval = View.findDrawableById("horloge_val") as Text;
            horval.locY = climblbl.locY + 55;
            horval.locX = 55 ;
            var battval = View.findDrawableById("battery_val") as Text;
            battval.locY = horval.locY;
            battval.locX = 190 ;
        var compteurval = View.findDrawableById("compteur_val") as Text;
            compteurval.locY = horval.locY;
            compteurval.locX = 120 ;
    (View.findDrawableById("hr_lbl") as Text).setText(Rez.Strings.hr_lbl);
    (View.findDrawableById("cad_lbl") as Text).setText(Rez.Strings.cad_lbl);
    (View.findDrawableById("pw_lbl") as Text).setText(Rez.Strings.pw_lbl);
    (View.findDrawableById("vit_lbl") as Text).setText(Rez.Strings.vit_lbl);
    (View.findDrawableById("dist_lbl") as Text).setText(Rez.Strings.dist_lbl);
    (View.findDrawableById("climb_lbl") as Text).setText(Rez.Strings.climb_lbl);
    (View.findDrawableById("time_lbl") as Text).setText(Rez.Strings.time_lbl);
    // The given info object contains all the current workout information.
    // Calculate a value and save it locally in this method.
    // Note that compute() and onUpdate() are asynchronous, and there is no
    // guarantee that compute() will be called before onUpdate().
    function compute(info as Activity.Info) as Void {
        // See Activity.Info in the documentation for available information.
            // le compteur va permettre de faire varier les info affichées selon les valeurs
            //il s'incrémente de 1 toutes les secondes.
              mSpeed = info.currentSpeed*3.6 as Float;
             if(info.timerTime != null and info.timerTime !=previous_time ){
              previous_time = mTime;
              mTime = info.timerTime;
              compteur = compteur+1;
                if(mTime<=5000){ // initialisation de l'altitude au démarrage
                        mAlt1 = info.altitude as Number;
                        mAlt2 = info.altitude as Number;
                        mAltInt1 = mAlt1.toNumber();
                        mAltInt2 =  mAlt2.toNumber();
                    } else {
                        mAltInt1 = mAltInt2;
                    //calcul du D+
                    if(mAltInt2>mAltInt1){ // si l'altitude actuelle est supérieure à la précédente, le D+ augmente
                    mClimb = mClimb + (mAltInt2 - mAltInt1) ;
                    else {
                    mClimb = mClimb;
              } else {
             // mClimb = 0d;
              //mTime = 0d;
              //compteur = 0d;
        // parce que parfois le timer est dans la même seconde 2 fois d'affilée, j'arrondis au dessus.
        timeArrondi= (mTime/1000.0)+.499;
        //conversion du temps en secondes et formatage pour l'affichage.
        mTimeSec = timeArrondi.toNumber();
        var hour = (mTimeSec / 3600).toLong();
        var minute = (mTimeSec / 60).toLong() - (hour * 60);
        var second = mTimeSec - (minute * 60) - (hour * 3600);
        if (mTimeSec < 3600) {
            mDuree = Lang.format("$1$:$2$", ([minute.format("%02d"), second.format("%02d")]));
        } else {
            mDuree = Lang.format("$1$:$2$:$3$", ([hour.format("%d"), minute.format("%02d"), second.format("%02d")]));
            if(info.currentHeartRate != null){
              mHR = info.currentHeartRate as Number;
              mHRMoy = info.averageHeartRate as Number;
              } else {
              mHR= 0d;
              mHRMoy = 0d;
            if(info.elapsedDistance != null){
              mDistance = info.elapsedDistance as Number;
              mDistKM = mDistance / 1000 as Float;
              vitesseMoyenne = 3600* mDistance / (mTime);
              } else {
              mDistance = 0d;
              mDistKM = 0.0f;
              vitesseMoyenne = 0;
            if(info.currentCadence  != null){
                mCad = info.currentCadence as Number;
                mCadMoy = info.averageCadence as Number;
              } else {
               mCad = 0d;
               mCadMoy = 0d;
             if(info.currentPower != null){
               mPW1 = mPW2;
               mPW2 = mPW3;
               mPW3 = info.currentPower as Number;
               mPW = (mPW1 + mPW2 + mPW3)/3;
              } else {
               mPW1 = mPW2;
               mPW2 = mPW3;
               mPW3 = 0d;
        horloge = System.getClockTime(); // ClockTime object
        horloge_text =(horloge.hour.format("%02d") + ":" +horloge.min.format("%02d") );
        batt_stat= System.getSystemStats();
        batt = batt_stat.battery;
            // every 5mn, counter is reset to zero
            if (compteur>reset_valeur){
                compteur=0;
            }else{
                compteur=compteur;
    // Display the value you computed here. This will be called
    // once a second when the data field is visible.
   function onUpdate(dc as Dc) as Void {
        // Set the background color
   (View.findDrawableById("Background") as Text).setColor(getBackgroundColor());
    var pw = View.findDrawableById("pw_val") as Text;
   if (getBackgroundColor() == Graphics.COLOR_BLACK) {
          pw.setColor(Graphics.COLOR_WHITE);
      } else {
           pw.setColor(Graphics.COLOR_BLACK);
      pw.setText(mPW.format("%d")+"w");
    if (compteur< reset_valeur-5)  {
            // la vitesse moyenne, cadence moy et freq cardiaque moy st affichées pendant 5" après 4mn55
        var vitesse = View.findDrawableById("vit_val") as Text;
                vitesse.setColor(Graphics.COLOR_WHITE);
            } else {
                vitesse.setColor(Graphics.COLOR_BLACK);
         vitesse.setText(mSpeed.format("%.1f"));
        var cad = View.findDrawableById("cad_val") as Text;
                cad.setColor(Graphics.COLOR_WHITE);
            } else {
                cad.setColor(Graphics.COLOR_BLACK);
        cad.setText(mCad.format("%d"));
        var HR = View.findDrawableById("hr_val") as Text;
            HR.setColor(Graphics.COLOR_WHITE);
            } else {
            HR.setColor(Graphics.COLOR_BLACK);
        HR.setText(mHR.format("%d"));
    } else{
            vitesse.setColor(Graphics.COLOR_BLUE);
            } else {
            vitesse.setColor(Graphics.COLOR_DK_BLUE);
         vitesse.setText(vitesseMoyenne.format("%.1f"));
            cad.setColor(Graphics.COLOR_BLUE);
            } else {
            cad.setColor(Graphics.COLOR_DK_BLUE);
          cad.setText(mCadMoy.format("%d"));
            HR.setColor(Graphics.COLOR_BLUE);
            } else {
            HR.setColor(Graphics.COLOR_DK_BLUE);
         HR.setText(mHRMoy.format("%d"));
        //mon ajout
    var distanceParcourue = View.findDrawableById("dist_val") as Text;
            distanceParcourue.setColor(Graphics.COLOR_WHITE);
        } else {
            distanceParcourue.setColor(Graphics.COLOR_BLACK);
        distanceParcourue.setText(mDistKM.format("%.2f"));
   var duree = View.findDrawableById("time_val") as Text;
            duree.setColor(Graphics.COLOR_WHITE);
        } else {
            duree.setColor(Graphics.COLOR_BLACK);
duree.setText(mDuree);
var denivele = View.findDrawableById("climb_val") as Text;
            denivele.setColor(Graphics.COLOR_WHITE);
        } else {
            denivele.setColor(Graphics.COLOR_BLACK);
        denivele.setText(mClimb.format("%d"));
var heure_actuelle = View.findDrawableById("horloge_val") as Text;
            heure_actuelle.setColor(Graphics.COLOR_WHITE);
        } else {
            heure_actuelle.setColor(Graphics.COLOR_BLACK);
         heure_actuelle.setText(horloge_text);
var battery_charge = View.findDrawableById("battery_val") as Text;
            battery_charge.setColor(Graphics.COLOR_WHITE);
        } else {
            battery_charge.setColor(Graphics.COLOR_BLACK);
         battery_charge.setText("Batt " + batt.format("%d")+"%");
        // Call parent's onUpdate(dc) to redraw the layout
        View.onUpdate(dc);
        // la mise en forme des lignes doit s'effectuer après la commande View.onUpdate(dc);
         dc.setColor(Graphics.COLOR_WHITE, Graphics.COLOR_WHITE);
          } else {
         dc.setColor(Graphics.COLOR_BLACK, Graphics.COLOR_BLACK);}
        dc.setPenWidth(1);
        dc.drawLine(0, 57, 200, 57);
        dc.drawLine(0, 130, 200, 130);
        dc.drawLine(0, 183, 200, 183);
        dc.drawLine(0, 240, 200, 240);
        dc.drawLine(85, 0, 85, 57);
       dc.drawLine(110, 130, 110, 240);
