Callbacks
I get an error, what am I doing wrong?
class MyClass
function doOnce()
System.println("test");
var a = method(:ontTest);
a.invoke();
function onTest()
System.println("passed");
results in
test
Failed invoking <symbol>
Invalid Value
@PC = 0x10000068
@PC = 0x10000068
@PC = 0x10000029
Invalid Value
Invalid Value
If I try
//System.println(a instanceof Method);
I get the same error.
  • Looks like a simple typographical error. Your function is onTest, but the symbol passed to method is ontTest.
    Oops....
    I made this test because I didn't get it to work. Have been staring at it for an hour :S
    Thanks.
    But then I'm still stuck with this:
    function pushMenu()
    var menu = new MainMenu();
    Ui.pushView(menu, new MainMenuInputDelegate(), Ui.SLIDE_RIGHT);
    class MainMenu extends Ui.Menu
    function initialize()
    setTitle("My menu");
    addItem("Start", method(:onStart));
    function onStart()
    Systen.println("onStart");
    class MainMenuInputDelegate extends Ui.MenuInputDelegate
    function onMenuItem(item)
    System.println("onMenuItem");
    System.println(item instanceof Method);
    item.invoke();
    Shouldn't this work? I don't want a long if/else construct in my onMenuItem, so I thought I'd just pass a method as item id.
    N.B I know for most cases I should use a resource for a menu, but the items won't always be the same.
    Pfff. Solved it. Thanks.
    addItem("Start", :onStart);
    var a = method(item);
    a.invoke();
    function onStart()
    System.println("onStart2");
  • Yeah. I discovered that one a while ago. Symbols are fun.
