90 digress
Would it be possible to turn a standard fenix 3 watch face 90 digrees to the perpendicular ?
Ie when your arms are out straight in front of you , you can read the watch face
    Former Member over 10 years ago
    I don't know what the fenix 3 watch face looks like, but if all information displayed in this watch face is available in connect IQ then this is possible.
    But.....
    - the watch face would need to be rebuild in connect IQ. Just turning it is not possible;
    - the current connect IQ framework does not allow for text to be drawn at a 90 degree angle, so that's a bit of a challenge (not impossible though, but the location of every letter has to be calculated and drawn with a custom font)
    Thank you for the reply
    When / if my watch ever gets deliverd I will look in to it further
  • I've reported this as a feature request for a future release. I know that we already have the ability to rotate bitmaps on the books.
    I assume you reporting rotating text as a feature request. That would be great Brandon.
  • Rotating bitmaps, rotating text, rotating screens, ... It seems that it might make sense to insert a transformation matrix between the user and display. That way anything could be rotated/scaled/offset directly and there would only be one system for doing so.
    That's a good idea only thought of watch faces ... :o
  • I assume you reporting rotating text as a feature request. That would be great Brandon.
    Yes, sorry. I should have been more clear. I have reported rotating fonts. :)
    Soooo just to clarifi ... If it's been reported ? Does that mean there isa chance it will happen ? As my fenix 3 has been dispatched and will be with me soooon
  • That's very good idea.
    What should be requested is not related to connect IQ only. Would be nice to have an option in watch for particular screen/widget/watchface "Rotate by..."(x degrees). Maybe just one global option.
    The same also in connect IQ SDK for some subsets like screen, font, text, bitmap.
    Fenix3 has square(plus rounded!) screen 218x218 so the feature might be trivial to implement ;)
    Thankyou :D
    But my question is who's babys do I have to have to make it happen ? :o
