Does the FR955 properly support DrawBitmap2() or not? It is listed in the list of supported devices for the function, but when I use it, in the simulator, I get messed up graphic images. The colors and the scaling transformation get messed up it seems. I don't know if it is a simulator bug, or the device doesn't really support the function.
I am using connectiq-sdk-win-7.2.1
It seems like there is an issue with the packingFormat attribute for the bitmap element in the drawables.xml file.
I am using png files. If I set packingFormat="png" drawBitmap and drawBItmap2 gives incorrect results. When I remove the packingFormat attribute entirely drawBitmap and drawBItmap2 work fine.
Now the question is what happens on a real device?
