Temporary view
Hi,
I wanted to know how to add a temporary view that disappear after a little while ;exactly like the lap in the running application for example : when there is a lap, you have a view that shows the number of the lap and the time elapsed (for example), and this view disappears automatically.
Thanks for your help.
Rgds
  • I provided code some time ago to display an alert that would automatically disappear after a timeout or after a key press. I've made a small change to it to follow new guidelines for the SDK, but it should still work to show what you need to do.
    You can find it here.
    Travis
    Ok, many thanks, I'll have a look on it.
    Rgds,
    Hi Travis,
    I try to implement your code, but the alert never appears, I put System.println in every method of the Alert class, there is never called.
    Where must we implement the
    new Alert({
    :timeout => 2000,
    :font => Gfx.FONT_MEDIUM,
    :text => "Quick Brown Fox",
    :fgcolor => Gfx.COLOR_RED,
    :bgcolor => Gfx.COLOR_WHITE
    I try on the onupdate(dc), but this didn't work too (I implement a datafield, maybe this is different ?)
  • In a DF, here's the way I'd handle this (I do the same in full blown apps, BTW).
    In onUpdate(), check for a "message screen", by looking for a non-zero value for something like "msgSeconds". If it's non-zero, display the message, else, display the regular screen.
    Then in compute(), if msgSeconds is non zero, do msgSeconds-- (compute() is called every second, so no timer needed (which you can't use in a DF anyway)).
    To display a message, (on what ever condition you want), you'd have something like:
    msg="message to display";
    msgSeconds=10;
    Hi jim_m_58,
    this is a very good idea !
    thanks !!
  • Sorry. I wasn't aware that you were trying to do this from within a data field. I don't believe that you can push views from data fields, so you'd have to implement something like Jim's suggestion.
    Travis
    Ok,
    no problem, I didn't tell it by the way.
    Jim suggestion is perfect, not to complicated for me :) I was able to implement it :)
    Thanks both.
    Rgds,
