how can i get the name of the device in my source code.
i want do adjust the watchface to compatible devices like fenix3, vivoactive and so on.
thanks
There are a couple of options:
- If using the xml layout system, you can specify resource folders with layout for each device / family
- If using dc to draw, you could use the screenShape to determine your layout
- Also when using dc to draw, you could get the part number and go from there.
- Another option when using dc to draw, is to specify resource folders with string resource for each device, and save the device name in a string resource
For resource folders, check out Overriding Resources in the Programmer's guide in your SDK folder.
Note that you can also use the new build file exclusions functionality to provide custom code for each device or device family.
Travis
