I changed to SDK 7.2.0 and "migrated" all my Edge Datafields to 7.2.0.
It was necessary to change all xxApp.mc files.
I use in all my datafields the (nearly) same code for inputDelegate Click Event.
It works in nearly all datafield without problems - only one Datafield throws an Error:
App.mc
import Toybox.Application; import Toybox.Lang; import Toybox.WatchUi; (:background) class EdgeAllinOne58App extends Application.AppBase { var view = null; function initialize() { AppBase.initialize(); } // onStart() is called on application start up function onStart(state as Dictionary?) as Void { } // onStop() is called when your application is exiting function onStop(state as Dictionary?) as Void { } /* up to SDK 2.6.4 //! Return the initial view of your application here function getInitialView() as Array<Views or InputDelegates>? { view = new EdgeAllinOne58View(); Background.registerForTemporalEvent(new Time.Duration(5 * 60)); return [ view, new InputDelegate(view) ] as Array<Views or InputDelegates>; } */ // from SDK 7 //! Return the initial view of your application here function getInitialView() as [Views] or [Views, InputDelegates] { view = new EdgeAllinOne58View(); Background.registerForTemporalEvent(new Time.Duration(5 * 60)); return [ view, new InputDelegate(view) ]; } function onBackgroundData(data) { System.println( "data=" + data ); if ( view != null ) { view.tempEdge = data; } } function getServiceDelegate(){ return [new SensDFServiceDelegate()]; } } function getApp() as EdgeAllinOne58App { return Application.getApp() as EdgeAllinOne58App; }
The error is thrown in the View.mc on the line (line 13 in below code):
//------------------------------------------------------------------- class InputDelegate extends WatchUi.BehaviorDelegate { // für tap Event var view; var tX; var tY; function initialize(v) { BehaviorDelegate.initialize(); view = v; } function onTap(clickEvent) { var tapCoordinates = clickEvent.getCoordinates(); tX = tapCoordinates[0]; tY = tapCoordinates[1]; if ( view.deviceInUse != 7 ) { if ( tX > 130 and tY < 100 ) { // tap auf Varia Batterie if ( view.showVariaBat == true ) { view.showVariaBat = false; } else { view.showVariaBat = true; } //System.println("TAP!"); return true; } } else { return false; } } }
