ERROR: Unable to load devices: null
C:\Users\user>java -Xms1g -Dfile.encoding=UTF-8 -Dapple.awt.UIElement=true -jar c:\Users\user\AppData\Roaming\Garmin\ConnectIQ\Sdks\connectiq-sdk-win-7.1.1-2024-04-17-66d0159ae\bin\monkeybrains.jar -o deneme8.prg -f c:\Users\user\OneDrive\Desktop\Garmin\Tutorial\deneme8\deneme8\monkey.jungle -y c:\Users\user\OneDrive\Desktop\Garmin\Tutorial\developer_key -d fenix5s_sim -w
usage: monkeyc [-a <arg>] [-b <arg>] [--build-stats <arg>] [-c <arg>] [-d <arg>]
[--debug-log-level <arg>] [--debug-log-output <arg>]
[--disable-api-has-check-removal] [--disable-v2-opcodes] [-e]
[--Eno-invalid-symbol] [-f <arg>] [-g] [-h] [-i <arg>] [-k] [-l <arg>]
[-m <arg>] [--no-gen-styles] [-o <arg>] [-O <arg>] [-p <arg>] [-r] [-t]
[-u <arg>] [-v] [-w] [-x <arg>] [-y <arg>] [-z <arg>]
-a,--apidb <arg> API import file
-b,--apimir <arg> API MIR file
--build-stats <arg> Print build stats [0=basic]
-c,--api-level <arg> API Level to target (deprecated)
-d,--device <arg> Target device
--debug-log-level <arg> Debug logging verbosity [0=errors, 1=basic,
2=intermediate, 3=verbose]
--debug-log-output <arg> Output log zip file
--disable-api-has-check-removalDo not optimize out API has checks
--disable-v2-opcodes Do not use the v2 opcodes
-e,--package-app Create an application package.
--Eno-invalid-symbol Do not error when a symbol is found to be
invalid
-f,--jungles <arg> Jungle files
-g,--debug Print debug output
-h,--help Prints help information
-i,--import-dbg <arg> Import api.debug.xml
-k,--profile Enable profiling support
-l,--typecheck <arg> Type check [0=off, 1=gradual, 2=informative,
3=strict]
-m,--manifest <arg> Manifest file (deprecated)
--no-gen-styles Do not generate Rez.Styles module
-o,--output <arg> Output file to create
-O,--optimization <arg> Optimization level [0=none, 1=basic, 2=fast
optimizations, 3=slow optimizations]
[p=optimize performance, z=optimize code
space]
-p,--project-info <arg> projectInfo.xml file to use when compiling
-r,--release Strip debug information
-t,--unit-test Enables compilation of unit tests
-u,--devices <arg> devices.xml file to use when compiling
(deprecated)
-v,--version Prints the compiler version
-w,--warn Show compiler warnings
-x,--excludes <arg> Add annotations to the exclude list
(deprecated)
-y,--private-key <arg> Private key to sign builds with
-z,--rez <arg> Resource files (deprecated)
SDK is working fine. All devices downloaded but getting this error for 4 days. I couldn't find a solution. Any suggestion?
