Hi all,
I am quite the novice with these smart-watch applications but I ran into an issue I have trouble solving myself.
I am trying to use the Garmin "makeOAuthRequest" mechanism and have lots of troubles here. First of all, I tried the Authentication.makeOAuthRequest approach but I cant the login page to appear at all. I tried lots of different parameters and configurations but the Login prompt does simply not appear (Connect IQ app running and everything).
Since that doesn't work, I am tinkering with the Communications.makeOAuthRequest and here I have the login prompt. My issue however is that I put in the defined redirect URI "http://localhost" and after the successful login I can see an "err::ERR_CONNECTION_REFUSED" appearing on screen with the info that something went wrong. What is interesting is that I can actually see the full HTML response call and a valid code inside that could be used to fetch a token.
How can I solve this issue?
- What is causing my Authentication.makeOAuthRequest to fail?
- What is causing the "err::ERR_CONNECTION_REFUSED" after a successful login using Communications.makeOAuthRequest?
I hope somebody can shed some light into this confusion, many thanks in advance!
