I see a few occurrences of a weird error in the ERA related to the onSettingsChanged() method in datafield. All the supported by my app devices with different firmware versions and languages are affected. However, I was never able to reproduce it on my own Edge device. Here is a shortened version of the code where it happens:
import MonkeyMath;
import Toybox.Activity;
import Toybox.Application;
import Toybox.Graphics;
import Toybox.Lang;
import Toybox.Math;
import Toybox.UserProfile;
import Toybox.WatchUi;
public class Power extends Component {
private var _ftp as Number;
private var _powerZoneLimits as Array<Number>;
private var _powerContainer as RollingAverage?;
private var _powerLabelDrawable as Text?;
public function initialize() {
Component.initialize();
_ftp = getNumberProperty("ftp");
_powerZoneLimits = computePowerZoneLimits();
var powerAvgSeconds = getNumberProperty("powerAvgSeconds");
_powerContainer = powerAvgSeconds > 1 ? new RollingAverage(powerAvgSeconds) : null;
public function compute(info as Info) as Void {
public function onLayout(dc as Dc, view as View) as Void {
_powerLabelDrawable = view.findDrawableById("powerLabel");
var powerLabelText = Lang.format(Application.loadResource(Rez.Strings.power), [
getNumberProperty("powerAvgSeconds"),
_powerLabelDrawable.setText(powerLabelText);
public function onUpdate(dc as Dc, textColor as ColorType) as Void {
public function onSettingsChanged() as Void {
var powerLabelText = Lang.format(Application.loadResource(Rez.Strings.power), [powerAvgSeconds]);
_powerLabelDrawable.setText(powerLabelText); // The Unexpected Type Error arises here according to ERA
So it points me to the Text.setText() method. But how is it even possible?
Even if we assume that ERA points to the culprit code row not precisely, I don't see the problem in a few previous rows as well.
For the lines 41, 43 the getNumberProperty() method looks like below:
public function getNumberProperty(propertyKey as String) as Number {
try {
var value = Properties.getValue(propertyKey).toNumber();
return value != null ? value : SETTINGS_DEFAULTS.get(propertyKey);
} catch (e) {
return SETTINGS_DEFAULTS.get(propertyKey);
public static const SETTINGS_DEFAULTS =
"ftp" => 200,
"powerAvgSeconds" => 3,
} as Dictionary<String, Number>;
I think it covers any "unhappy" scenario during the property retrieval:
- If Properties.getValue() fails internally then the catch block will return the default prop value from the constant dictionary;
- If Properties.getValue() returns null then the NPE will be thrown and the catch block will return the default prop value from the constant dictionary;
- If Properties.getValue() returns a String that is not parsable to Number then, according to the documentation, toNumber() will return null and the default prop value will be taken from the constant dictionary;
- If the Properties.getValue() returns a parsable String then it will be successfully cast to Number (the behavior that we usually see when changing settings from Android);
- If Properties.getValue() returns a Number then it will be successfully returned as is after the toNumber() invocation.
Line 42 cannot be a culprit as well, or in another case, the ERA would show a deeper stack trace.
Line 44 looks also fine - all types seem to be correct and, if something were wrong inside the new RollingAverage() constructor, then the stack trace would point inside the constructor.
Line 45 - simple Lang.format() call with 2 non-null arguments.
Line 46 - simple Text.setText() call with String argument since Lang.format() always returns a String.
My simplified properties file looks like this:
<properties>
<property id="ftp" type="number">200</property>
<property id="powerAvgSeconds" type="number">3</property>
</properties>
The simplified settings file:
<settings>
<setting propertyKey="@Properties.ftp" title="@Strings.ftp">
<settingConfig type="numeric" min="50" max="1000"/>
</setting>
<setting propertyKey="@Properties.powerAvgSeconds" title="@Strings.powerAvgSeconds">
<settingConfig type="numeric" min="1"/>
</setting>
</settings>
It defines that the type of settings are numeric and that they may have some min and max values.
The simplified strings file:
<strings>
<!-- settings labels -->
<string id="ftp" scope="settings">Functional threshold power</string>
<string id="powerAvgSeconds" scope="settings">Number of seconds to average current power</string>
<!-- display labels -->
<string id="power">Power $1$s</string>
</strings>
I'm totally lost in assumptions about what may be wrong here and how to reproduce the problem.
