Hi There
I'm new to developing garmin widget apps and I am trying to build the following:
- Fetching Data from a rest backend - array of items
- show for each item a view with the ViewLoop
I was able to fetch data and show them on a simple label on a static view. As next I tried to adjust me widget depending on the "primates"-example with the ViewLoop in it.
As far as I understand is the PageIndicatorFactory the entrypoint of the ViewLoop an initializes the Views. I'm not sure where to put the fetch-data mechanism to show dynamically views, depending of the response of the request. In other words: The ViewLoop must wait with it's init process until I have fetched the data.
Do you have an idea how this could be solved?
kind regards Leon
