I know I can use Attention has :ToneProfile in the CODE, but I'd rather spare the unfunctional parts fro the user by not displaying the relevant SETTINGS for devices that don't have it. For this I'd need a way to generate the monkey.jungle either :
Each device folder has a file called {device id}.debug.xml, which contains the text "ToneProfile" if and only if the device supports Attention.ToneProfile.
From the SDK Devices folder (in macOS…
Thanks!
Here's my customized version:
#!/usr/bin/env bash METHOD="$1" EXCLUDE_ANNOTATION="${2:-$1}" if [ x"${METHOD}" == x"" ]; then echo "Usage: $0 <methodName>" [<excludeAnnotation>] …
From the SDK Devices folder (in macOS terminal, linux shell, or Windows WSL shell), you can run the following *nix shell commands (bash or zsh should work):
(Skip to the lines starting with if you're only interested in the commands you need for the end result, as opposed to "background info" stuff.)
- Determine the number of files named "*.debug.xml" (there's one for each device):
# find . -name "*.debug.xml" | wc -l
136
- List the path of each "*.debug.xml" file, in sorted order
# find . -name "*.debug.xml" | sort
./approachs60/approachs60.api.debug.xml
./approachs62/approachs62.api.debug.xml
./approachs7042mm/approachs7042mm.api.debug.xml
./approachs7047mm/approachs7047mm.api.debug.xml
- List the number of "*.debug.xml" files which contain the text "ToneProfile":
# grep -R ToneProfile -l --include="*.debug.xml" | wc -l
110
- List the number of "*.debug.xml" files which do not contain the text "ToneProfile":
# grep -R ToneProfile -l --include="*.debug.xml" -L | wc -l
26
- List the path of each file containing the text "ToneProfile":
# grep -R ToneProfile -l --include="*.debug.xml" | sort
./d2airx10/d2airx10.api.debug.xml
List each device ID with ToneProfile support:
# grep -R ToneProfile -l --include="*.debug.xml" | sort | cut -d/ -f2
approachs7042mm
approachs7047mm
d2airx10
List each device ID without ToneProfile support:
# grep -R ToneProfile -l --include="*.debug.xml" -L | sort | cut -d/ -f2
approachs60
approachs62
d2air
legacyherocaptainmarvel
legacyherofirstavenger
legacysagadarthvader
legacysagarey
venu
venu2
venu2s
venu2system6preview
venud
venusq
venusq2
venusq2m
venusqm
vivoactive
vivoactive3
vivoactive3d
vivoactive3m
vivoactive3mlte
vivoactive4
vivoactive4s
vivoactive5
vivoactive_hr
vivolife
You should be able to pass the lists generated by the latter two commands to your script/program which generates monkey.jungle (or incorporate those commands in your script.)
Thanks!
#!/usr/bin/env bash METHOD="$1" EXCLUDE_ANNOTATION="${2:-$1}" if [ x"${METHOD}" == x"" ]; then echo "Usage: $0 <methodName>" [<excludeAnnotation>] exit 1 fi DEVICES_DIR="${CIQ_SDK_HOME}/Devices" (cd "${DEVICES_DIR}" ; grep -R "${METHOD}" -l --include="*.debug.xml" | sort | cut -d/ -f2 | sed -e "s#\$#:no_${EXCLUDE_ANNOTATION}#" ; \ grep -R "${METHOD}" -l --include="*.debug.xml" -L | sort | cut -d/ -f2 | sed -e "s#\$#:${EXCLUDE_ANNOTATION}#") | sort
This is the example from the SDK documentation:
// Play a predefined tone if (Attention has :playTone) { Attention.playTone(Attention.TONE_LOUD_BEEP); } // Use an array of ToneProfile objects to build and play a custom tone if (Attention has :ToneProfile) { var toneProfile = [ new Attention.ToneProfile( 2500, 250), new Attention.ToneProfile( 5000, 250), new Attention.ToneProfile(10000, 250), new Attention.ToneProfile( 5000, 250), new Attention.ToneProfile( 2500, 250), ]; Attention.playTone({:toneProfile=>toneProfile}); }
It's not clear if we need to check for both playTone and ToneProfile or one of then is sufficient.
Based on the debug.xml-s either one of them should be enough, because either both are defined or both aren't.
