Is it the number of ms in which no vibration occurs?
Hello,
I just wanted to try and help you with any confusion with dutyCycle. In a nutshell, the dutyCycle controls the frequency (think KHz) many times perceived as the "strength" of the vibration. I am linking another thread that talks a little more in depth about the use of dutyCycle for your reference as well.
Hi Coleman, thanks for pointing me in the right direction. I considered to use it as a metronome in a data field. Let's say, the cadence falls below 180, the metronome kicks in for a while. Unfortunately, I can't use timer callbacks in datafields, I. E. I have only the 1 second compute timer. Am I right?
Thanks for explaining a little further. You are correct in your assumption. You’re probably better of writing an app so that you can use the correct timer. Hope this helps.
