<properties>
<property id="HomeAerodrome" type="string" />
<property id="ShowMetarAge" type="boolean">false</property>
<property id="DisplayUnits" type="number">0</property>
<property id="AlwaysUseCelsius" type="boolean">true</property>
<property id="UseQnhHeader" type="number">0</property>
<property id="OnlyDisplayCeilingCloud" type="boolean">true</property>
<property id="GetPositionEachUse" type="boolean">false</property>
<property id="vwNumNearest" type="number">4</property>
<property id="vwStnX" type="number">30</property>
<property id="vwStnY" type="number">35</property>
</properties>
The first seven properties are all attached to user configurable settings and the last three properties are values I use to customize the view (hence the 'vw' prefix) and override these values in the resource files for other devices.
I reread the documentation and could find no reason not to do this, especially since I want these values to be overridden per device and since these are not user-editable values. Should I not be doing this? It seems odd that it works fine with Garmin Express but not with GCM.
Cheers,
Douglas
