onStorageChange() not being called
I grab my EDGE's device Temp using an every 5 minute BG temporal process. Working great. Right now check every second for the background saved Storage Value. But that value only potentially changes once every 5 minutes, so that is wasted processing.
In the simulator, I just tried to replace my manual storage value check with "onStorageChange()". But this is never called.
I know Storage is being written to, since I added a "println" in my background process where Background.exit(data) values are written using Storage.setValue().
I also use "onSettingsChanged()", and that works perfectly for when I make a User Setting change.
Any tricks to get "onStorageChanged()" to trigger? Seems straight forward. Weird that it isn't being called.
Thanks!
