makeWebRequest working on simulator but not device
Hi as per title, I don't see why this is not working on the device itself but works fine on the simulator?
The server side code simply receives the request in javascript as:
if (req.body.request && req.body.request === "urlplz") {
And here is the monkey c code:
function onReceive(responseCode as Number, data as Dictionary or String) as Void{
        if (responseCode == 200) {
            var idplz = Storage.getValue("id");
            if (idplz == null) {
                Storage.setValue("id", data["id"]);
            if (data["yt"].equals("true")) {
                mode= true;
                Storage.setValue("mode", "true");
            yes = data["url"];
            WatchUi.pushView(new $.View(), new $.Delegate(), WatchUi.SLIDE_UP);
        } else {
    function makeRequest() {
            idplz = "notavailable";
        var url = "myurl.url;
        var params = {                                              // set the parameters
              "request" => "urlplz",
              "urlcode" => idplz
        var options = {
            :method => Communications.HTTP_REQUEST_METHOD_POST,
            :headers => {
                "Content-Type" => Communications.REQUEST_CONTENT_TYPE_JSON
            :responseType => Communications.HTTP_RESPONSE_CONTENT_TYPE_JSON
        Communications.makeWebRequest(url, params, options, method(:onReceive));
AND I have also tried it this way which also works fine on the simulator but not the physical device, where I just swapped the params into the headers:
                mode = true;
            yes = data["url"];
            WatchUi.pushView(new $.View("okay"), new $.Delegate(), WatchUi.SLIDE_UP);
        } else {
            WatchUi.pushView(new $.View("error"), new $.Delegate(), WatchUi.SLIDE_UP);
        var url = "myurl.url";
        var options = {
            :headers => {
                "Content-Type" => Communications.REQUEST_CONTENT_TYPE_JSON,
                "request" => "url",
                "urlplzsir" => code
        Communications.makeWebRequest(url, null, options, method(:onReceive));
with the server side javascript code accepting it as:
if (req.headers['request'] && req.headers['request'] === "gimme") {
