Why does watchface with complication display Obj:?
Creating a new watchface from Visual Code and the code snippet from https://developer.garmin.com/connect-iq/core-topics/complications/ displays "Obj:' and an associated object number.
I've looked at ComplexWF from jim_m_58, https://forums.garmin.com/developer/connect-iq/f/discussion/349473/simple-example-wf-that-shows-a-bunch-of-things.  It's a great example but I would like to build a watchface from scratch and better understand complications.
I could not use the insert code function from the forum so I pasted my code below.
Why does this code compile and show "Obj: 166" on the simulator and a real device?
import Toybox.Application;
import Toybox.Graphics;
import Toybox.Lang;
import Toybox.System;
import Toybox.WatchUi;
import Toybox.Complications;
class CaloriesCompView extends WatchUi.WatchFace {
    function initialize() {
        WatchFace.initialize();
    // Load your resources here
    function onLayout(dc as Dc) as Void {
        setLayout(Rez.Layouts.WatchFace(dc));
    // Called when this View is brought to the foreground. Restore
    // the state of this View and prepare it to be shown. This includes
    // loading resources into memory.
    function onShow() as Void {
    // Update the view
    function onUpdate(dc as Dc) as Void {
        // Get the current time and format it correctly
        var timeFormat = "$1$:$2$";
        var clockTime = System.getClockTime();
        var hours = clockTime.hour;
        if (!System.getDeviceSettings().is24Hour) {
            if (hours > 12) {
                hours = hours - 12;
        } else {
            if (getApp().getProperty("UseMilitaryFormat")) {
                timeFormat = "$1$$2$";
                hours = hours.format("%02d");
        var timeString = Lang.format(timeFormat, [hours, clockTime.min.format("%02d")]);
        // Update the view
        var view = View.findDrawableById("TimeLabel") as Text;
        view.setColor(getApp().getProperty("ForegroundColor") as Number);
        view.setText(timeString);
        // Call the parent onUpdate function to redraw the layout
        View.onUpdate(dc);
        // Get device width and height
        var MyW = dc.getWidth();
        var MyH = dc.getHeight();
        // Code from developer.garmin.com/.../
        var cals = Complications.getComplication(
         new Id(Complications.COMPLICATION_TYPE_CALORIES)
        // Print cals
        dc.setColor(Graphics.COLOR_WHITE, Graphics.COLOR_TRANSPARENT);
        dc.drawText(MyW*.5, MyH*.6, Graphics.FONT_MEDIUM, cals, Graphics.TEXT_JUSTIFY_CENTER);
    // Called when this View is removed from the screen. Save the
    // state of this View here. This includes freeing resources from
    // memory.
    function onHide() as Void {
    // The user has just looked at their watch. Timers and animations may be started here.
    function onExitSleep() as Void {
    // Terminate any active timers and prepare for slow updates.
    function onEnterSleep() as Void {
