Hi. Is there a way to fix the title of Custom Menus so it does not scroll together with the list of menu items and instead stays on top?
Not easily, but you can dynamically change the menu such that when you scroll you add/remove menu items so the title would always be displayed at the top. So, you are not really scrolling the menu, but changing what is in the menu when you scroll.
Thanks! I thought as much. Seems like too much of a hassle. Is there a simple working example someone can share? Would it still be under a CustomMenu class? This is the only example I found on GitHub: Protomolecule Watchface
I've done similar things, but don't have an example of this. Just know it's possible. This could be done for a standard Menu2 or a Custom Menu.
Note, I recently reported quite a few bugs with custom menus. forums.garmin.com/.../many-bugs-in-menu2-custommenu-on-devices-and-in-the-sim
