Just developed watch face with an animation which should be shadowed on Instinct 2 series to make it 'greyed'.
Have used checkered BufferedBitmap created with
It seems I need to rephrase my question:
Is it any way to apply checkered mask (to get grayscale effect) over generated image on Instinct 2 series?
Search this forum for "checkerboard". It's something that can be used for low power mode with an AMOLED display, but lets you have a black rectangle, can me used to make it look gray, by setting every other pixel to white
Thank you Jim,
I have used checkerboard for AMOLEDS via dc.drawBitmap(...
For the Instinct 2 series I want to implement 'grayscale' mode applying over rendered image a pre-rendered and stored checkerboard. Unfortunately it seems doesn't work on real Instinct 2 series devices. I just need to know is it possible to draw on Dc some pre-rendered BufferedBitmap with transparency (ie one color is Black, other one is Transparent) with a real transparency effect?
If you look at the checkerboard posts, I do it with a custom font, setting the colors to foreground and background of the screen. This makes half the pixels the foreground color and half the background. No transparency in the custom font.
Do you meant this one post
https://forums.garmin.com/developer/connect-iq/f/discussion/275493/checkerboard-for-aod-display-i-made#pifragment-1298=2
If yes, I can't get idea how to use it to draw polygons on Instinct 2 series. Thank you and Sorry for asking so many times for a help!
