"Old" Multi-WebRequest in 6.4.X
Hi
With SDK 4.x.x I had a workflow for 3 webrequests in one. Also solved by this forum. Now I try the same in 6.4.X. In the simulator, I can see the 3 request were succesfully done. But the println says error.
Any Ideas?:
My Code:
using Toybox.Background as Bg;
using Toybox.Communications as Comm;
using Toybox.System as Sys;
using Toybox.Application.Storage as Ast;
using Toybox.Time as T;
using Toybox.Lang;
(:background)
class MyServiceDelegate extends Sys.ServiceDelegate {
 function initialize(){ServiceDelegate.initialize();}
 var res1=null,Code1=null,res2=null,Code2=null,res3=null,Code3=null;
 var lat=Ast.getValue("V2lastLat");
 var lon=Ast.getValue("V2lastLong");
 var appid1=Ast.getValue("V2appid1");
 var dndOffline=Ast.getValue("V2dndOffline");
 var dndSys=Sys.getDeviceSettings().doNotDisturb;
 var owmCount=Ast.getValue("V2owmCount");
 var tempUnits=Ast.getValue("V2tempUnits");
 var langi=Ast.getValue("V2langi");
 function onTemporalEvent() {
  if(dndOffline==true&&dndSys==true){
  }else{
   if(Sys.getDeviceSettings().phoneConnected==true){
    if(owmCount==0){ //Nur noch zwei Abfragen machen. 1. Current+alerts,dailysum,geolocation
      var url1="">api.openweathermap.org/.../onecall";
      var param1={"lat"=>lat,"lon"=>lon,"exclude"=>"minutely,daily,hourly,alerts","appid"=>appid1,"units"=>tempUnits,"lang"=>langi};
      var opt1={};
      var met1=method(:responseCallback1);
      Comm.makeWebRequest(url1,param1,opt1,met1);
    }else{
 function responseCallback1(responseCode,data) {
 if(owmCount==0){
  var url2="api.openweathermap.org/data/3.0/onecall/day_summary";
  var param2={"lat"=>lat,"lon"=>lon,"date"=>"2023-12-01","appid"=>appid1,"units"=>tempUnits};
  var opt2={};
  var met2=method(:responseCallback2);
  Comm.makeWebRequest(url2,param2,opt2,met2);
  res1=data;
  data=null;
  Code1=responseCode;
  Sys.println("Res1 mit owmCount=0: "+res1);
  Sys.println("Code1 mit owmCount=0: "+Code1);
 }else{
 function responseCallback2(responseCode,data){
  var url3="api.openweathermap.org/geo/1.0/reverse";
  var param3={"lat"=>lat,"lon"=>lon,"limit"=>"1","appid"=>appid1};
  var opt3={};
  var met3=method(:responseCallback3);
  Comm.makeWebRequest(url3,param3,opt3,met3);
  res2=data;
  data=null;
  Code2=responseCode;
  Sys.println("Res2 mit owmCount=0: "+res2);
  Sys.println("Code2 mit owmCount=0: "+Code2);
 function responseCallback3(responseCode,data){
  res3=data;
  data=null;
  Code3=responseCode;
  Sys.println("Res3 mit owmCount=0: "+res3);
  Sys.println("Code3 mit owmCount=0: "+Code3);
  Background.exit([res1,Code1,res2,Code2,res3,Code3]);
From the console:
Background: Res1 mit owmCount=0: {current=>{feels_like=>-0.970000, clouds=>100, uvi=>0, sunrise=>1701436722, wind_gust=>12.350000, dew_point=>3.450000, humidity=>95, sunset=>1701471483, wind_deg=>30, pressure=>1004, dt=>1701418139, rain=>{1h=>0.560000}, temp=>4.180000, visibility=>9656, weather=>[{main=>Rain, description=>light rain, icon=>10n, id=>500}, {main=>Mist, description=>mist, icon=>50n, id=>701}], wind_speed=>8.230000}, timezone=>America/Chicago, lat=>38.855400, timezone_offset=>-21600, lon=>-94.799400}
Background: Code1 mit owmCount=0: 200
Background: Res2 mit owmCount=0: null
Background: Code2 mit owmCount=0: -1001
Background: Res3 mit owmCount=0: null
Background: Code3 mit owmCount=0: -1001
And in the HTTP Traffic Log from the sim: 3x times code 200 and 3 times the correct contents for my ApiGet...
Thanks for any help
