Hi,
I'am trying to get the data from my light electric vehicles (LEV) via ANT.
I started with the Moxy sample and can now connect to the bike.
But How do I have to interpret the data out of the payload ?
Any help really appreciated
Hi,
from where have you received all this information. Is there an ANT document explaining this?
I am also search from the Power produced by the motor [W] an the human power produced by the biker [W]
This is shown in the Fazua Mobile APP, but not listed in your code.
Hi Seli17
I‘m trying to write a datafield for Ant+ LEV for my Specialized Levo 2019. All I want is to connect to bike and read ID, battery status and support level. Unfortunately I did not manage so far to come along.
I downloaded Ant+_LEV from ThisisAnt and I will attach it here. Maybe it is of any help for you.
In revers I would be very grateful if you could share your code which would certainly help me to get along…
Thanks!
Hi MC,
First step:
I took the Moxy Sample of Garmin and changed the deviceType to 20
So I could connect my Fenix to my Fazua Bike.
MOSensor.mc
//const DEVICE_TYPE = 31; //Muscle Oxygen
//const DEVICE_TYPE = 11; //Bike Power
const DEVICE_TYPE = 20; //Light Electric Vehicle
Second step:
I read the payload according to
https://github.com/maca88/E-Bike-Edge-MultiField/blob/master/Source/EBikeEdgeMultiField/source/EBikeSensor.mc
for the moment, (I am really at the beginning) I did for Battery Charge only:
function parsePage3(payload, data) {
data.batteryCharge = parseBatteryCharge (payload);
hidden function parseBatteryCharge(payload) {
return (payload[1] & 0x7F); // Battery SOC (State of Charge)
function onMessage(msg) {
// Parse the payload
var payload = msg.getPayload();
if( Ant.MSG_ID_BROADCAST_DATA == msg.messageId ) {
var pageNumber = (payload[0] & 0xFF);
if (pageNumber == 1)
//if( MuscleOxygenDataPage.PAGE_NUMBER == (payload[0].toNumber() & 0xFF) ) {
// Were we searching?
if (searching) {
searching = false;
// Update our device configuration primarily to see the device number of the sensor we paired to
deviceCfg = GenericChannel.getDeviceConfig();
var dp = new MuscleOxygenDataPage();
//data.batteryTemperature = parseBatteryTemperature(payload);
dp.parse(payload, data);
// Check if the data has changed
if (pastEventCount != data.eventCount) {
pastEventCount = data.eventCount;
} else if (pageNumber == 3) {
dp.parsePage3(payload, data);
//data.batteryCharge = parseBatteryCharge (payload);
} else if(Ant.MSG_ID_CHANNEL_RESPONSE_EVENT == msg.messageId) {
if (Ant.MSG_ID_RF_EVENT == (payload[0] & 0xFF)) {
if (Ant.MSG_CODE_EVENT_CHANNEL_CLOSED == (payload[1] & 0xFF)) {
// Channel closed, re-open
open();
} else if( Ant.MSG_CODE_EVENT_RX_FAIL_GO_TO_SEARCH == (payload[1] & 0xFF) ) {
searching = true;
} else {
//It is a channel response.
It is only proof of concept, it works with FAZUA Ride 60 and Fenix 6X but should also work with your bike!
Hope this helps you
I am interested in BikePower and MotorPower, but this is not in LEV but shown on the Fazua App.
There is only Assist in %, but this is only half of what I need.
I will try to ask FAZUA where they transmit this information.
Many Thanks Seli17!
I‘m also working on Moxy sample base, but I‘m afraid, I had deleted too much of code I was thinking I do not need .
So - back to the start!
Regarding rider power: my Spesh Levo sends rider(bike) power as „normal“ sensor. I get bikepower and cadence simply by searching and connecting my Levo as power sensor. No Ant programming necessary - only activity.info.currentPower and currentCadence
I will report back!
Hi Seli17
I managed to get batterySOC, assistMode, totalAssistModes to work.
I followed your steps, but simply parse the variables inside of onMessage() and then I pass it via function call from/to MoxyField.mc
I tested the output on my Edge 1040 and with my Spesh Levo - it works!
public function onMessage(msg as Message) as Void {
//if ((Ant.MSG_ID_BROADCAST_DATA == msg.messageId) && ($.PAGE_NUMBER == (payload[0].toNumber() & 0xFF))) {
if ( Ant.MSG_ID_BROADCAST_DATA == msg.messageId) {
if (pageNumber == 1) {
if (_searching) {
_searching = false;
_deviceCfg = GenericChannel.getDeviceConfig();
_data.parse(msg.getPayload());
// Update the event count
_pastEventCount = _data.getEventCount();
batSOC = (payload[1] & 0x7F); //battery Status
travelMode = (payload[2] >> 3 & 0x07); //Assist Mode
} else if (pageNumber == 5) {
totalAssistModes = (payload[2] >> 3) & 0x07; // Number of Assist modes supported
} else if (pageNumber == 80) {
manufacturerId = (payload[5] << 8) | payload[4]; // Manufacturer ID
} else if ((Ant.MSG_ID_CHANNEL_RESPONSE_EVENT == msg.messageId) && (Ant.MSG_ID_RF_EVENT == (payload[0] & 0xFF))) {
open();
} else if (Ant.MSG_CODE_EVENT_RX_FAIL_GO_TO_SEARCH == (payload[1] & 0xFF)) {
_searching = true;
Next step:
reduce and rename the Moxy datafield to my needs for my LEV datafield.
A question: Does the datafield work in the simulator if a ANT dongle is connected to the PC?
Problem for me to test: my PC is upstairs and my eBike downstairs. Too wide range for connection I assume...
All tests I do are with the datafield sideloaded to the Edge - it's a litte complicated.
I added activity.info.currentPower and currentCadence to my BigFont DataField and have now to add the Moxy (LEV) stuff to it.
What Edge do you have?
I have no ANT dongle, I am testing directly with my Fenix to my bike, not very confortable!
=> so same as you
