Hi
With recents options power budget is exceded when font is
Why so much consumption
Hi
Use "Watchface diagnostics" instead of the profiler for investigation of this. Remember, it's a 30ms max average over a minute, and with watch face diagnostics, you can see the value every second.
There are things like loadResource() that will cause the the power budget to be exceeded if used in onPartialUpdate. Your clip region can also do it even with small draws. Multiple clip regios also get combined, so if you have a small clip region at the top and another small one at the bottom, the clip region becomes the top row of the top region to the bottom row of the bottom region.
Not sure about vector fonts, but with custom fonts, they have a bigger impact on the budget than regular native fonts, so you can't use a custom font that's as high as a native font.
I'd experiment with things like the size of the vector font and clip region using watch face diagnostics to help narrow things down. I don't think the profiler will help much in this case.
Jimmy
I use exactly the same clip for both fonts.
The fonts are preloaded at the start of the program
If I use my user font the power budget is never exceeded
If I use the internal Garmin font with the dc.drawAngledText function the power budget explodes
Ok, so I hacked one of my watch faces to use a vector font and dc.drawRadialText() in onPartialUpdate for the seconds. Normally, I use drawText() and the same font I use for HH:MM. I kept the clip region the same as before.
It's run for about 10 minutes in low power with no issue with the power budget. It might be 1-2ms more with the vector font, but that's it.
I do Graphics.getVectorFont() in onLayout() (You can see I also use it on the left and right arcs but only in high power) In your call, I see you are using dc2 and not Graphics for the call. Where are you doing that?
I understand my mistake
In onpartialupdate, I made dc.clearClip(); event if I made a little rectangle erase (size of seconds)
If I delete this now power budget is less than 8000.
It's curious in my configuration watchface diagnostics doesn't have an auto update like in a previous version
Thanks Jim for your answer Didier
