Garmin sensor data finally catching up to apple?
  • Add the wheelchair API usages to the ActivityTracking sample.
  • Add support for setting sampling frequency to 100hz for real-time accelerometer data.
  • Add APIs for getting real-time gyroscope and magnetometer data. Gyroscope supports sampling rates up to 100hz, whereas magnetometer supports up to 50hz.
I just checked the release notes, and noted the above features added.
Notice for accelerometer it says add support to set sample freq to 100hz, where as magnetometer and gyro it says rates up to 100, up to 50.
Do you think that was a typo, or I can assume on all devices to force a 100hz sample rate accelerometer is now possible?
I can't seem to find any info on the API that allows this 100hz ( What is wheelchair API? )
If anyone knows anything, or can point in the direction of any tech documents that would be appreciated
