Sideloading not working anymore?
I used to copy .prg files in the /APPS folder when I was testing a watchface, but this does not seem to work anymore. Is there anyway to fix this?
  • What version of FW is on your watch and what SDK are you using to build the .prg?
    If you build with the 1.2.x SDK, it won't run as a sideload on a watch that has the new beta FW with a 1.3.0 or 2.1.0 CIQ VM. You'll see a "signing error" in ciq_log.txt.
    There's a sticky post at the top of this forum that talks about app signing.
  • Thank you for that.
    I'm using the latest fw7.34 on a F3 with CIQ 1.3.0
    Sideloading a CIQ SDK 1.2.11 built did not work, which was expected, but with 2.1.0 everything was fine.
