Weird Problem - Just for Discussion
All,
I know this can't be solved by the forum, but I wanted to just post it, as I can't find a solution without removing the code. It also could trigger somebody else with the same or similar problem.
My original line is below, and this fails with 'Failed invoking <symbol> UnexpectedTypeException: Expected String, given null'
values[valueIndex+1] = [heartrateToString(info.currentHeartRate)];
Now, I know, there's a few things that can go wrong here, so after some messing around, I changed to the code below, but still get the same error.
values[valueIndex+1] = null;
Again, the variables may be invalid, or the index too high, so using println, here's what I get:
Sys.println(valueIndex+1); returns 5
Sys.println(values.size()); returns 6
Sys.println(values[valueIndex+1]); returns null
So basically the index is in range and value is currently null, but when I try to set to any value (including null) I get the same error.
Even more weird, the line before the error is similar, and works perfectly.
values[valueIndex] = [heartrateToString(info.averageHeartRate)];
Basically, I am lost! Discuss.
Cheers
Chris
  • I'm guessing this in in a data field and in compute().
    Are you doing any check for info.currentHeartRate being null? It will be null before the recording has started.
  • Thanks Jim for the response.
    It's within a onUpdate on a App.
    That was my initial reaction. The purpose of the function heartrateToString is to check for null on the property (currentHeartRate) and format an output, as well as formatting a real value. I also checked for info being null.
    Therefore that's why I took it back to barebones and just tried assigning the most basic value null, which also fails. So this fails too values[valueIndex+1] = null;
    Cheers
    Chris
  • Which exact line of code are you getting the error on?
  • The initial line was:
    But this also fails
    This:
    Returns:
    null
    So, these two lines:
    Print these lines to the Console
    null
    Cheers
    Chris
  • Why are you doing:
    instead of:
    values[valueIndex+1] = heartrateToString(info.currentHeartRate);
    It seems you want to put a string in the array. Yet you also put null into the array (not an empty string but a null)
  • This array is passed to my UI render class. If the Array has a single length, the value is rendered on the UI. If it has two values, the second indicates the colour to render as.
    So it can be populated as ["157"] to render 157 in the default colour, otherwise elsewhere it could be ["157", Gfx.COLOR_RED] to render 157 in Red. Other parts of the code are executing this.
    The render class then checks the size, and if 2 in length, calls setColor first with the second parameter.
    I know this is not impacting this line, as it fails whatever is on the right-hand side of the equals, as I tried a range of values to see if that was the fault.
    Do eithervalues[valueIndex] = [heartrateToString(info.currentHeartRate)];orvalues[valueIndex+1] = [""];work?
  • It seems you want to put a string in the array. Yet you also put null into the array (not an empty string but a null)
    Maybe I am not being clear. I don't want to put null in the array, I just wanted to show the right-hand side had no impact on the error, as no matter what it always failed.
  • Do eithervalues[valueIndex] = [heartrateToString(info.currentHeartrate)];orvalues[valueIndex+1] = [""];work?
    No, sorry just tried, and the first works, and the second fails.
    Assuming you are using eclipse.....
    I have had a couple of strange eclipse errors in the past. Pretty sure it wasn't me :). It was like the file was cached or something, and updates weren't being read. I would suggest copy/pasting into an external file. Delete original file. Restart eclipse. Recreate file.
