Hi all,
I am writing here because I have recently updated eclipse, and I am having issues trying to add a new run config or modifying an existing one. I have two issues:
- Parts of the running config like the name or the API level cannot be seen properly
- Everytime I try to add a new run config there is an issue that can be seen on the left side of the image which says "Index Out of Bounds"
The problem can be seen in the following image.
Eclipse version is 2023-06 (4.28.0), build id: 20230608-1333, and Connect IQ version is 4.1.2 for both the IDE and the SDK manager (seen in Eclipse through Help->Install new software)
Do you have any ideas of what may be wrong?
Thanks,
Javier
